Helicoil
Posted: Fri Nov 19, 2021 5:54 pm
by Mzobanzi
Hi Guys.
My Cylinder head bolt hole threads that holds the plate for injectors are damaged. Can helicoil threads repair works.
Your advice will be appreciated.
Sent from my M2006C3MG using Tapatalk
Re: Helicoil
Posted: Fri Nov 19, 2021 6:26 pm
by Callum229
Yes it will have to be embedded more inside or maybe get someone to weld on that piece(aluminium) and insert coil.
Or put a timesert/ threaded insert. That will work just make sure the insert is deep enough.
Re: Helicoil
Posted: Fri Nov 19, 2021 6:45 pm
by Mzobanzi
Thank you very much.
Re: Helicoil
Posted: Fri Nov 19, 2021 9:22 pm
by Jetta2
Those bolts are torqued down with massive amounts of torque, so a helicoil will strip very easily, so don't even go that route.
First stage torque - 3Nm
Second stage - 90 degrees
Third stage - 180 degrees
A Timesert thread repair will work, read about it being done on a few motors and no issues.
Re: Helicoil
Posted: Sat Nov 20, 2021 9:51 am
by Mzobanzi
Jetta2 wrote:Those bolts are torqued down with massive amounts of torque, so a helicoil will strip very easily, so don't even go that route.
Thanks man. Where can l find Time sert in Johannesburg??
