My Cylinder head bolt hole threads that holds the plate for injectors are damaged. Can helicoil threads repair works.
Your advice will be appreciated.
Sent from my M2006C3MG using Tapatalk
Thanks man. Where can l find Time sert in Johannesburg??Jetta2 wrote:Those bolts are torqued down with massive amounts of torque, so a helicoil will strip very easily, so don't even go that route.
First stage torque - 3Nm
Second stage - 90 degrees
Third stage - 180 degrees
A Timesert thread repair will work, read about it being done on a few motors and no issues.
