Page 1 of 3
8v Turbo.. with Ko3
Posted: Mon Jul 23, 2012 10:49 am
by Mange
hey guys
1st off we all know about the 16v Turbo conversion :grin: but thats not what im asking about.
so please no negative comments, or hey thats stupid bla bla bla i DOnt care ! .
if you have usefull information that would add light to my topic then your more than welcome :grin:
I am looking at putting a hairdryer onto my 8v .... im not looking for monster boost and a million KW's :oops: although that would be nice . haha
the reason i dont want to go the 16v route is that i am getting the turbo parts really cheap off a friend and it will work out allot cheaper than doing the 16v Turbo conversion for me.
Parts i know i need :
Turbo T25/28
Turbo manifold
wastegate
Dump Valve
intercooler
piping for intercooler and downpipe
oil return from turbo into sump
and the 3mm turbo head gasket to lower the compression
fuel pressure regulator
oil pressure gauge to be safe
bigger injectors
and then re tuning my Dicktator for it
i DONT plan on running higher than 0.5bar through my motor maybe in the future like over a year or 2 ill bump it up .......
Parts i need ? ......
Re: 8v Turbo
Posted: Mon Jul 23, 2012 11:07 am
by 1.8iblackie
You already have a fpr in your standard rail. Maybe just look at a beter fuel pump but if your only aiming for 0.5bar maybe the standard pump would be fine.
If your only boosting 0.5 you dont need to go 3mm on spacer. 2mm wil be fine unless u want to boost more in future.
Your clutch might not be happy with the new found toque.
Youve got most of the things covered there, but theres always small things that pop up along with the build.
-f your going to get a custom manifold to use that waste gate you need to make sure of your spacing cause spacing sucks on a u-flow head end head soak is a bastard so get a proper heat sahield to put between the inlet and turbo manifolds and if you can afford to get the turbo mani ceramic coatetd thats gonna help alot.
8vT's are fun. And there is really no point in making more than 350Nm in a mk1 cause you cant put it down.
Good luck.
Re: 8v Turbo
Posted: Mon Jul 23, 2012 11:11 am
by panic-mechanic
Ok what bits are you getting for cheap? Ie. what do you have ro get made up / pay expensive for.?
Re: 8v Turbo
Posted: Mon Jul 23, 2012 11:25 am
by smoothscott
if you planning on only running a T28 on 0.5 bar then an internal wastegate is easier and cheaper. I've been running my u-flow turbo for almost 18 months and it runs like a dream...
Re: 8v Turbo
Posted: Mon Jul 23, 2012 11:50 am
by Mange
Thanks guys its nice to look at a thread and it hasnt been shut down by bad comments ......
@panic parts im getting cheap are :
Turbo Brand new so no need to have it rebuilt
Turbo manifold im getting brand new for under R500
piping im not going with the aluminium now coz its crazy expensive
and the intercooler im getting pretty cheap aswell ....
i dont plan on rushing the build at all !!! iv tried rushing a 16v motor and i paid through my assssss with school fee's .....
i wanna build up all the parts together then save up a few grand to keep as safety for all the little things that WILL go wrong or leak etc
Re: 8v Turbo
Posted: Mon Jul 23, 2012 12:36 pm
by panic-mechanic
Ok all the stuff you get cheap are the things that really does not matter whether it is a 16v or an 8v. But anyway. I dislike 8v u-flow because you always have space and always have massive heat issues and always have an issue with getting oil drains done etc.
If you really have to build an 8v then try do it on a x-flow.
Re: 8v Turbo
Posted: Mon Jul 23, 2012 12:50 pm
by Jetta2
Been there done that, and I think I used the T-shirt as an oil rag :lol:
As Stephan said, go X-flow 8V-T.
U-flow is do-able, but believe me, doing a turbo setup on an 8V X-flow is 1000 times easier than doing it on a U-flow.
Re: 8v Turbo
Posted: Mon Jul 23, 2012 4:18 pm
by Gplay
:iagree: +10000000000
Re: 8v Turbo
Posted: Tue Jul 24, 2012 7:47 am
by Gplay
see much easier and more simple to install a x-flow
Re: 8v Turbo
Posted: Tue Jul 24, 2012 8:39 am
by Mange
oooooo thats pwetty !!!!!!!!
only prob is the X flow heads are scarce arent they ? ......
i know theres one on the forum but its been worked to the heavens and the price is pretty expensive
where does one find a standard X flow head ?
Re: 8v Turbo
Posted: Tue Jul 24, 2012 8:48 am
by Gplay
Mange wrote:oooooo thats pwetty !!!!!!!!
that you have keep searching... junk mail, gumtree, people who stock import engines... dont rush if you really want it it will come to you :troll:
Re: 8v Turbo
Posted: Tue Jul 24, 2012 4:14 pm
by Mange
im ok with waiting for a head to pop up .....
is there a specific code on the head that i should be looking for ?
and round about what price would be fair to pay
Re: 8v Turbo
Posted: Tue Jul 24, 2012 4:43 pm
by Gplay
Mange wrote:im ok with waiting for a head to pop up .....
Jetta2 can help you with the codes...
about 2grand mark i would say will be a fair price.
Re: 8v Turbo
Posted: Wed Jul 25, 2012 5:03 am
by 1.8iblackie
You get a couple of different castings for the cross flow head.
If U can get a German castings its first prize but the Mexican castings is the most easily obtainable. I can get a Mexican casting that's already ported and flowed with a big vale conversion for around R3200.
Its definitely the way to go if 8vT is your thing. I going for another dyno next week on a new cam aiming for around 210kw and 400Nm.
Bit more detail
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=143315
Regards
Reinier
Re: 8v Turbo
Posted: Wed Jul 25, 2012 5:34 am
by 1.8iblackie
Just might be your lucky day. Looking at the water ports the head is in a very very good condition.
Good price for the head.
http://www.streetracing.co.za/forum/vie ... f=4&t=7045
Re: 8v Turbo
Posted: Wed Jul 25, 2012 10:44 am
by Mange
thanks 1.8iblackie ...def worth a look !!....
theres a guy selling a 1.8 cross flow head for R1500 i havnt seen the condition of it but apparently its in good nick ...
Do i Need the 2.0l head or will the 1.8l head work aswell ?
Please will you post the results of the Dyno up !!! id be really interested to see !
Re: 8v Turbo
Posted: Wed Jul 25, 2012 11:39 am
by kalamazoo
Like blackie said about the x flow head is better .Ive done my turbo setup on a normal head and can see that it is a problem because there is no space and a lot of mods to be made like your gear links and the heat of the turbo to close to the rubbers of stearing collum .
Re: 8v Turbo
Posted: Wed Jul 25, 2012 11:41 am
by Mange
yea iv decided to go with the x flow set up to make my life easier ...... thanks guys !
now just to find out it the 1.8 X-flow head will bolt straight on to my 2l bottom
Re: 8v Turbo
Posted: Wed Jul 25, 2012 12:03 pm
by Gplay
Mange wrote:yea iv decided to go with the x flow set up to make my life easier ...... thanks guys !
its not a straight bolt on.. be careful... you have to send it in to get the oil hole welded :troll:
Re: 8v Turbo
Posted: Wed Jul 25, 2012 12:33 pm
by Mange
ok thats alright .... cause i plan on getting the head and then cleaning it up and get everything 100% before i "bolt it on" ....
@Gplay your motor looks pretty sexy ! good work man
Re: 8v Turbo
Posted: Wed Jul 25, 2012 1:06 pm
by Gplay
Mange wrote:ok thats alright .... cause i plan on getting the head and then cleaning it up and get everything 100% before i "bolt it on" ....
yeah thats the best....
thanks for the kind words my man :grin:
Re: 8v Turbo
Posted: Wed Jul 25, 2012 1:49 pm
by panic-mechanic
Depending on which head you have ro semi weld one oil port closed and deill out 2 of the head bolt holes.
Re: 8v Turbo
Posted: Wed Jul 25, 2012 1:53 pm
by Mange
thanks panic ..... so the 1.8 X-flow head will work ?????
Re: 8v Turbo
Posted: Wed Jul 25, 2012 2:05 pm
by panic-mechanic
I have never seen a 1.8 x-flow head as they were basically either 1.6 or 2l but yes i suppose if you can find such an animal it should work.
Re: 8v Turbo
Posted: Wed Jul 25, 2012 2:06 pm
by Mange
maybe it is a 2l lol i havnt seen it yet but ill try get pics up here of it etc
Thanks Panic
