To use motorex pistons or ks? For 2l16v t shortblock?
maranou
Postby maranou » Fri Jan 08, 2010 7:58 pm
Car melt piston on no 4 and need new pistons,poeple say motorex just as good as ks or even beter,and wane use hasting rings becaus has cromoly coated top ring and cheaper than cofab that take forever to seat.
http://www.vwclub.co.za/phpbb3/viewtopic.php?f=11&t=72987
Golf 2l16vT 320kw 520nm
1/4mile @ 12.2 kilarney 2011
800m @ 233km/h
Re: To use motorex pistons or ks? For 2l16v t shortblock?
Postby panic-mechanic » Fri Jan 08, 2010 9:10 pm
Sorry don't know motorex so my choice would be KS. Hastings are fine cofap is better if you going for a long term build. Have you sorted the reason it went lean....
'07 Audi S6 V10 - beast !!!!!
'07 Audi A4 2l TDI
'95 Audi 90 coupe quattro
lampredi
Postby lampredi » Fri Jan 08, 2010 9:43 pm
The problm with motrex based on wot i hear 4rm experianced engine builder: the ring groove on pistons wear quiker. So its not the rings thats the problem with motrex,its the piston ring grooves.(inferior causing premature wear) as compared to ks. Many misinterprate this and buy good rings,thinking that better than motrex rings wil sort ths out.in a performance engn u wil get black smoke sooner etc. Cos pistns quality cause ring groove wear quiker.
maranou
Postby maranou » Fri Jan 08, 2010 9:52 pm
Panic : Stil doing examination why it run lean on piston 4,can be injector but new 700cc bosch but gone test it,can be oring leak but did test after startup with carb cleaner? Can be intake leak,gone try to presure test it,can be timing or feul but on dyno heard no pinging with nock detecter earphone thing?
Did make 316kw on 1.5bar on afgas.
Wil try to post picks tomoro of pistons and intake
800m @ 233km/h
shannon ekermans
Postby shannon ekermans » Sat Jan 09, 2010 4:45 am
if you have one of those cast or log type manifolds that places the turbo very close to a particular piston then you will melt that piston all the time. the heat will lean out that cylinder more than the others due to running much hotter. and you wont know it cause only that cylinder will be recieving more temp.
something like this Image
golf 94 cti
105kw
Postby panic-mechanic » Mon Jan 11, 2010 7:20 am
Shannon - I disagree. There is nothing in an exhaust that will make a piston melt. The piston melts when it's on a power stroke and at that point the intake and exhaust valves are both closed. There is literally one reason for a melting piston and that is being too lean. If it's detonation then it shows pit marks and they usually crack.
'07 Audi A4 2l TDI
VeeRar6ix
Postby VeeRar6ix » Mon Jan 11, 2010 8:28 am
shannon ekermans wrote:if you have one of those cast or log type manifolds that places the turbo very close to a particular piston then you will melt that piston all the time. the heat will lean out that cylinder more than the others due to running much hotter. and you wont know it cause only that cylinder will be recieving more temp.
Disagree
By saying so, why doesn't the cylinder head itself melt if its too close to the turbo?
2008 Velociti 1.4i
1995 Jetta 12v VR6 Turbo 6 speed 4WD
(Ex headache)
1995 Jetta 24v VR6 Turbo
Turbo lag: the number of seconds the guy in the other car thinks he is winning...
shannon ekermans
Postby shannon ekermans » Mon Jan 11, 2010 8:33 am
i guess you learn something every day. its just what i got told buy someone who makes turbo manifolds. he was working on a opel superboss that had burnt cylinder 4 three times already and that was his theory. it made sense to me but then again im no expert on this sort of thing.
golf 94 cti
105kw
Return to “General Tech Discussions”
Users browsing this forum: No registered users and 45 guests
