Golf MK1, fuel tank removal.
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 2:28 pm
Anybody taken one out recently?
How much pain am I in for?
How exactly does it come out?
Please, please, pretty please, tell me the axle doesn't have to come out...
MacMan
Car Model: MKV GTi
Membership No: 478
Re: Golf MK1, fuel tank removal.
Post by MacMan » Fri Oct 23, 2009 2:35 pm
BlueBlob wrote:Anybody taken one out recently?
Ummm it's not the most difficult thing to do... it's just **** because it's under the car.
You just loosen all the hoses and then there are 2 straps holding it in. Each strap is bolted to the body with a 13mm nut. Once the straps are loose, the tank can slide out.
You don't have to remove the whole axle, I just dropped the one side, but dropping the whole axle will make it easier.
'06 UG Golf MKV GTi - 208Hp / 322Nm @ KAR (DP + Intake)
| DIY+ | S3 short shift | Flowtech DP | ITG Maxogen | REVO2 | Autotech HPFP | RCD 510 | H&R |
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
Velofox
Car Model: '94 FoxT 2.0 16v'
Membership No: 1314
Post by Velofox » Fri Oct 23, 2009 2:38 pm
sorry mate axle must just be loosened (4 bolts holding it up) try and mark it before you remove, just to ensure
that the axle goes back into the position it was...
there is 2 straps holding it up, loosen the 2 bolts, then the petrol down pipe and over flow must be removed and that is held in place by clamps...
and dare i say it , Blobs your uncle...
Current Rides
1994 2.0 16v FoxT - Lexy
1998 2.0 8v Mk3 GTI - Liesy
My Inspiration
16vT Engine Pics
Image Image Image Image
Velofox
Membership No: 1314
Post by Velofox » Fri Oct 23, 2009 2:40 pm
oh yes and unplug the float before you remove it....
plug located on the inside under the black cover below the seat, oh ya you dont have that seat...lol
Current Rides
My Inspiration
16vT Engine Pics
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 2:47 pm
Thanks guys.
Doesn't sound like as much work as I thought.
Will rip it out tonight quickly.
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 2:49 pm
Oh, reason for this:
We dyno'd my new motor last night. Went fantastically well up to 240kw at teh wheels when we started running out of fuel.
Car is now getting a fuel cell, surge tank, 10mm fuel lines (x2) and two fuel pumps. Let's see the fucker run out of fuel now. :evil:
kmg4real
Car Make: Volkswagen; BMW
Car Model: CITI 2.0 16VT; E36 323i
Membership No: 1381
Post by kmg4real » Fri Oct 23, 2009 2:54 pm
BlueBlob wrote:Oh, reason for this:
240kw? That's some awesome power for Teh Blob
:lol: :lol: :lol:
'02 CITI Golf 2l 16VT 243hp 306Nm @0.8 bar on M.R.D. Dyno - codename: [url=http://www.vwclub.co.za/forum/viewtopic ... BlaqSmithe[/url]
'98 BMW 323i
Ex - '98 Polo Playa 1.6i
Ex - '11 BMW 320d
Ex - '08 BMW 320i Facelift
Ex - '07 Citroen C2 iPlay
Ex - '07 Golf V GTI
Ex - '04 Audi 1.9TDi 6 spd
Ex - '02 CITI Golf 1.4i
FACT: "I use not only the brains I have, but all that I can Borrow." - Einstein
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 2:54 pm
kmg4real wrote:240kw? That's some awesome power for Teh Blob
:lol: :lol: :lol:
Thanks man.
The idea is to get to 280kw. Will stop there 'cause I don't think a stock bottom-end will like much more than that.
UDC
Membership No: 1041
Post by UDC » Fri Oct 23, 2009 2:57 pm
BlueBlob wrote:We dyno'd my new motor last night. Went fantastically well up to 240kw at teh wheels
:crazy: what you running under that hood
Velofox
Membership No: 1314
Post by Velofox » Fri Oct 23, 2009 2:58 pm
you have a new WHAT!!!!!
what a way of letting us know...
Current Rides
My Inspiration
16vT Engine Pics
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 3:10 pm
Velofox wrote:you have a new WHAT!!!!!
Sorry man. Not spending as much time here as I used to.
Yeah, melted the previous motor, so built a new one. Same spec though, bar one or two little secret changes. :lol:
Basically makes 30hp more as the previous one, at the same boost level, and we can now actually get more than 1.2 bar. Well, we will, as soon as the fuel delivery problems are sorted.
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 3:15 pm
UDC wrote: :crazy: what you running under that hood
2.0 16V Turbo.
neighbourhood terror
Car Model: 2010 Golf MK6 TSi
Post by neighbourhood terror » Fri Oct 23, 2009 3:36 pm
Peice of piss .. even easier on your car as the exhaust isn't in the way. Fitted the tank in my race car when I built it in about 10mins by myself :wink:
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 3:42 pm
neighbourhood terror wrote:Peice of piss .. even easier on your car as the exhaust isn't in the way. Fitted the tank in my race car when I built it in about 10mins by myself :wink:
Schweet. Feel like taking one out in 10 minutes tonight?
Velofox
Membership No: 1314
Post by Velofox » Fri Oct 23, 2009 3:47 pm
AAARRRRRRR, i wanna see the Blob also mos...
Time more or less?
Current Rides
My Inspiration
16vT Engine Pics
Post by neighbourhood terror » Fri Oct 23, 2009 3:49 pm
BlueBlob wrote:Schweet. Feel like taking one out in 10 minutes tonight?
Ok ... I'm game, sms me time
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 3:50 pm
Let's make it 19:00?
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 3:51 pm
Velofox wrote:AAARRRRRRR, i wanna see the Blob also mos...
Time more or less?
You want to pop around?
Anything after 19:00 should be fine.
Post by neighbourhood terror » Fri Oct 23, 2009 3:58 pm
BlueBlob wrote: Let's make it 19:00?
Cool ... it's a ummm date
BlueBlob
Post by BlueBlob » Fri Oct 23, 2009 3:59 pm
*runs for the hills*
sjs
Car Model: Citi & Megane RS 275 Final
Membership No: 1315
Post by sjs » Fri Oct 23, 2009 8:57 pm
You can also check my link when I converted to fi. Like MAcman said, its not difficult just f*cking annoying, would be easier with an extra hand http://www.vwclub.co.za/phpbb3/viewtopi ... &start=250
kmg4real
Membership No: 1381
Post by kmg4real » Mon Oct 26, 2009 8:20 am
That was some record time I say. Would you agree Dave?
'98 BMW 323i
Ex - '11 BMW 320d
Ex - '07 Golf V GTI
BlueBlob
Post by BlueBlob » Mon Oct 26, 2009 10:36 am
Ha ha.
What was it, like 4 hours or something?
But it's out. Picked up the fuel cell this morning. PURE PORN. I love welded aluminium...
Post by neighbourhood terror » Mon Oct 26, 2009 2:34 pm
Yup ... bit of a fail on my part really :oops: . Should have mentioned that when I did it there was no brake or fuel lines to deal with Also stuffing around trying to leave the brake lines in place wasted allot of time, we should have just dropped the whole axel in the first place and it would have taken half the time :bang:
Only glad I could help out though.
Velofox
Membership No: 1314
Post by Velofox » Mon Oct 26, 2009 2:53 pm
Ha ha.
was a nice 4 hours if i must say so myself...
why you not posting pics?
Current Rides
My Inspiration
16vT Engine Pics
