Wiring Diagram
Nad786GP
Car Model: Mk1 2dr L
Wiring Diagram
Post by Nad786GP » Thu Oct 01, 2009 6:40 am
Not sure where to post this so Im tryin here. I need sum help. im lookin for a complete wiring diagram for a mk1 golf. 1979 1100. Help please. :crazy:
2dr Mk1 L Backyard Special
Current-1979 2dr 1.1 now 1.8 16vT
Ex-1978 2dr 1.8 16v cover car vdub July08
Ex-1978 2dr 1.8 16v-wrote off
Ex-1989 mk2 1.8 csx with Gti inspiration
Digit Riaan
Re: Wiring Diagram
Post by Digit Riaan » Thu Oct 01, 2009 6:50 am
Nad786GP wrote:Not sure where to post this so Im tryin here. I need sum help. im lookin for a complete wiring diagram for a mk1 golf. 1979 1100. Help please. :crazy:
Good luck, please let me know if you find one! I have been looking for the last few months but no luck, I can not even get a fuse / relay layout.
Mine's wiring is still very good, I just need to sort the hooter. You can come and check on mine if you want.
What's the problem?
The wiring is more similar to the same time beetle / Polo Mk1 than any thing else.
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100 383, '79 Golf LS
Hers: '10 Mitsubishi Outlander
Velofox
Car Model: '94 FoxT 2.0 16v'
Membership No: 1314
Re: Wiring Diagram
Post by Velofox » Thu Oct 01, 2009 7:42 am
What's the problem?
whats wrong with your hooter?
Current Rides
1994 2.0 16v FoxT - Lexy
1998 2.0 8v Mk3 GTI - Liesy
My Inspiration
16vT Engine Pics
Image Image Image Image
Digit Riaan
Re: Wiring Diagram
Post by Digit Riaan » Thu Oct 01, 2009 7:56 am
What's the problem?
Out of order...I can not get it to work and thought it might be a relay. I do not just yet want to pull the wiring apart as it is still original. I checked all the fusues and they are all sharp! I pulled one relay and took it to VW, they quoted me R500! Luckily it was the rear window wiper one and not the hooter.
It's kinda hard driving in JHB without a hooter!
This is all I could find (large for better viewing):
RoadHaWg
Membership No: 731
Re: Wiring Diagram
Post by RoadHaWg » Thu Oct 01, 2009 8:13 am
There'r those full wiring diagrams in the Haynes manual, but they make absolutely NO sense whatsoever to me!
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
"We've all been raised on television to believe that one day we'd all be millionaires, and movie gods, and rock stars. But we won't. And we're slowly learning that fact. So we build VDubs son..."
"Owning a MK1 varies between having sex to getting hit in the balls. Usually several times in one day."
Digit Riaan
Re: Wiring Diagram
Post by Digit Riaan » Thu Oct 01, 2009 8:16 am
RoadHaWg wrote:There'r those full wiring diagrams in the Haynes manual, but they make absolutely NO sense whatsoever to me!
Went to look at the Haynes manual for my Golf on Sat, it's got a different fuse box. There is one pic of the right one, but they only say "Fuse box on earlier models"...
RoadHaWg
Membership No: 731
Re: Wiring Diagram
Post by RoadHaWg » Thu Oct 01, 2009 8:26 am
Ya man. Flipping haynes manual.
Yopu sit with something in a Million pieces wondering how to put it together. Go consult the haynes and all it says is "Refitting is the opposite of removal! :bang: :bang:
Stuart
1966 Splitty.
No Mk1 ;(
Nad786GP
Re: Wiring Diagram
Post by Nad786GP » Thu Oct 01, 2009 12:13 pm
Thanx man. will see if that diagrams can help.
kevincti.
Car Model: 2004 golf Gti R
Re: Wiring Diagram
Post by kevincti. » Sun Oct 04, 2009 3:53 pm
pm sent
maranou
Re: Wiring Diagram
Post by maranou » Sun Oct 04, 2009 7:19 pm
nad 786 gp and porno ster pm me your email and i will send the vw diagrams/files i have from a 83 rabbit mk1
a sample
Golf 2l16vT 320kw 520nm
1/4mile @ 12.2 kilarney 2011
800m @ 233km/h
Tdi03
Car Model: 2010 scirocco 2.0t sportline
Membership No: 1242
Re: Wiring Diagram
Post by Tdi03 » Sun Oct 04, 2009 8:02 pm
@ porno_ster. there is a conversion that are done on the golf 1 hooter. there are two wires coming from the loom to the hooter. try find out what one gives the earth when you press the horn. then conect that one to the horn. get another wire wired up from the other terminal to the positive on the battery.
hope it helps.
2010 Roc sportline 2.0 tsi
Stock
Digit Riaan
Re: Wiring Diagram
Post by Digit Riaan » Mon Oct 05, 2009 7:02 am
maranou wrote:nad 786 gp and porno ster pm me your email and i will send the vw diagrams/files i have from a 83 rabbit mk1
a sample
Hi,
Thanks. I also have the '83 one, but it is different to the pre '80 ones. Check pic above.
Digit Riaan
Re: Wiring Diagram
Post by Digit Riaan » Mon Oct 05, 2009 7:03 am
Tdi03 wrote:@ porno_ster. there is a conversion that are done on the golf 1 hooter. there are two wires coming from the loom to the hooter. try find out what one gives the earth when you press the horn. then conect that one to the horn. get another wire wired up from the other terminal to the positive on the battery.
hope it helps.
Hi,
Are you saying it has permanent +12v and switched -12v?
kevincti.
Re: Wiring Diagram
Post by kevincti. » Mon Oct 05, 2009 8:28 am
guys i got some diagrams but its in pdf. its the whole cars wiring layout . pm me your email if interested
Digit Riaan
Re: Wiring Diagram
Post by Digit Riaan » Mon Oct 05, 2009 8:33 am
kevincti. wrote:guys i got some diagrams but its in pdf. its the whole cars wiring layout . pm me your email if interested
For which car(s)?
kevincti.
Re: Wiring Diagram
Post by kevincti. » Mon Oct 05, 2009 11:52 am
im not sure but its for the old golf, maybe 2 door.
Tdi03
Membership No: 1242
Re: Wiring Diagram
Post by Tdi03 » Mon Oct 05, 2009 1:07 pm
hope it helps.
Hi,
That is not how it came from the factory, from the factory (iirc) both wire have positive on and when you press the horn it pulse a negative on one wire. so the horn does'nt work while the key is out of the ignition.
porno_ster wrote:Are you saying it has permanent +12v and switched -12v?
If you do the conversion it will basicly work like that, but will also work if the key is out offf the ignition
Stock
Digit Riaan
Re: Wiring Diagram
Post by Digit Riaan » Mon Oct 05, 2009 1:37 pm
Tdi03 wrote:
hope it helps.
Hi,
Cool, thanks. I'll check.
abf16v
Re: Wiring Diagram
Post by abf16v » Tue Nov 17, 2009 11:46 am
hi< I am wondering if you can help me....I am a new member to your fourm and i am looking for a 2004 - 2007 citi golf wiring diagram and wondering if you can help.....thank you
2l 16valve
Car Make: Opel
Car Model: Corsa GSi
Re: Wiring Diagram
Post by 2l 16valve » Mon Nov 18, 2013 8:33 pm
I know this is old but i really need a wiring diagram for my gt, the fuse box doesnt look like the one porno_ster posted
2003 Opel Astra GSi
1982 Golf GT
2000 Opel Corsa GSi - 2.0l 16v
2006 Chev Aveo 1.5 - Stock Standard
1995 Opel Kadett 200t S - stock except lowering springs
1997 Opel Corsa 130iE - 70/40mm drop, corsa gsi mags, Viper f/f & exhaust.
1989 Opel Kadett 160GSE - Stock Standard
