Timing for dummies
Rezizter
Car Model: 135
Membership No: 1531
Timing for dummies
Post by Rezizter » Wed Aug 19, 2009 2:56 pm
on the 8v motor i know that when i turn the dizzy the idle gets better or worse
Question is, could anyone explain in detail, how to do this properly, perhaps how to use a timing light properly, and how do you know if you are TDC, or 6 degrees tdc, or well any degree Tdc.
Should timing be done at certain intervals, if so how?
Something thats always puzzled me.
Any input would be appreciated
Regards
Shaun
Current: 2011 BMW E82 135i Alpina White - Stock
ex: 2008 Seat Cupra 1.9tdi Zenith Grey - stock
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=150579
ex:2005 Velociti 1.6i - Dark Metallic Blue (sold)
ex: 2005 Velociti1.4i - White (stolen)
ex: 95' WHITE CITI (i'll always miss you)(blew up)
I'd rather push my VW than drive an Opel
DIE HARD MK1 FAN
Digit Riaan
Re: Timing for dummies
Post by Digit Riaan » Wed Aug 19, 2009 3:01 pm
Rezizter wrote:on the 8v motor i know that when i turn the dizzy the idle gets better or worse
Regards
Shaun
http://en.wikipedia.org/wiki/Ignition_timing
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100 383, '79 Golf LS
Hers: '10 Mitsubishi Outlander
neighbourhood terror
Car Model: 2010 Golf MK6 TSi
Post by neighbourhood terror » Wed Aug 19, 2009 3:08 pm
In short you should be messing with it. The timing on your car (I assume you're refering to the Velocity) is controlled by the EFI, thats why you don't have any advance mechanism on the distributer. There is a base timing setting which which is set at a specific engine RPM but once thats set you leave the distributer alone. Moving the distributer can mess up the fuel consumption and cause engine damaging detonation and rob you of performance
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker » Wed Aug 19, 2009 3:13 pm
neighbourhood terror wrote:In short you shouldn't be messing with it.
Fixed up :cool:
Current rides:
Hyundai - 1.4 Getz (daily)
Post by neighbourhood terror » Wed Aug 19, 2009 3:25 pm
Fixed up :cool:
Ah yes ... thanks :wink:
dhirennaidoo
Car Model: 9n Polo Classic TDi (PD100)
Post by dhirennaidoo » Thu Aug 20, 2009 12:54 pm
neighbourhood, where do you get those renders from your sig?
2012 Mk6 GTi Ed35
'09 Honda CBX250 Twister
Ex : '91 Fox 1.8, Honda CBR600F, '05 Polo Classic TDi (PD100)
Post by neighbourhood terror » Thu Aug 20, 2009 1:17 pm
dhirennaidoo wrote:neighbourhood, where do you get those renders from your sig?
From here > http://database.mangacars.fr/categories.php?cat_id=256
Found one of a Mk1 then edited it to match my car
:wink:
Rezizter
Car Model: 135
Membership No: 1531
Post by Rezizter » Thu Aug 20, 2009 3:15 pm
Thanks porno ster, exactly what i was looking for.
Shot for the help guys, good thing you told me about the efi... or else i would have had one broken little velo.
Fortunately i have a few mates with carb cars, so i'll practice my new found skills on their cars :evil: (i can see alot of people having to walk from next week :oops:
Regards
Shaun
DIE HARD MK1 FAN
MacMan
Car Model: MKV GTi
Membership No: 478
Post by MacMan » Thu Aug 20, 2009 3:57 pm
Regards
Shaun
The reason the idling changes when you turn the distributor is because you are advancing and retarding the ignition timing.
To set the timing on an 8V VW motor, you need to line up the 3 timing marks and then adjust the ignition timing using a timing light.
Lining up the 3 timing marks:
The mark on the cam pulley is a line on the inside of the pulley (facing the battery) and at TDC this mark must be level with the bottom of the tappet cover.
The rotor must point to the mark on the side of the distributor (you will need to take the plastic cover under the rotor off to see it).
There are 2 "flat pieces" on the flywheel and the mark you are looking for will be in between these 2 "flat pieces". This mark is either a punch mark (small round hole) and / or a v-type line cut into the flywheel and this mark must be in the middle of the inspection hole on the gearbox.
If you chose to use the punch mark (small round hole) then the motor is now at TDC. If you chose to use the V-type mark cut into the flywheel, then the motor is now at 6 degrees BTDC.
Adjusting the ignition timing:
Carb:
* Disconnect the vacuum pipe going to the vacuum advance unit on the distributor.
* Loosen the 13mm bolt that holds the clamp on the distributor shaft to prevent it from turning.
* If you used the punch mark (small round hole) then you will need an adjustable timing light and set it to 6 degrees advance. Then shoot the timing light at the mark on the flywheel and turn the distributor until the mark appears in the middle of the inspection hole.
* If you used the V-type mark cut into the flywheel, then you can use a static timing light, or an adjustable timing light set to 0 degrees. Then shoot the timing light at the mark on the flywheel and turn the distributor until the mark appears in the middle of the inspection hole.
* Tighten the 13mm bolt that holds the clamp on the distributor shaft to prevent it from turning.
MP9:
* You will need to get a VAG-COM, connect the diagnostic cable to the diagnostic port in your car and go to Group 1 under basic settings in the Engine menu. This will increase the revs to +- 1500rpm.
'06 UG Golf MKV GTi - 208Hp / 322Nm @ KAR (DP + Intake)
| DIY+ | S3 short shift | Flowtech DP | ITG Maxogen | REVO2 | Autotech HPFP | RCD 510 | H&R |
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
Rezizter
Car Model: 135
Membership No: 1531
Post by Rezizter » Fri Aug 21, 2009 9:40 am
gosh macman, thanks very much, thats exactly what i wanted to know.
Thanks again, brilliant write up.
Regards
Shaun
DIE HARD MK1 FAN
dhirennaidoo
Post by dhirennaidoo » Fri Aug 21, 2009 10:50 am
:wink:
Shot! :grin:
EDIT : They even had a pic of my classic!! Too wicked :grin:
2012 Mk6 GTi Ed35
Dj lost
Post by Dj lost » Fri Aug 21, 2009 3:46 pm
U only line up all 3markings for cambelt changes or when u change cam to get belt on and have all 3 perfect again
'07 Ford Bantam
'11 Ford Bantam
WESBANK Modıfıed mk1 replıca
SOLD
'07 Audi A4 B7 1.8T
'06 Polo 1.9tdi 96kw
'07 Audi A3 2.0FSI
'97 VW Citi Chico 2.0i
'71 Leyland Mini 1000 Stationwagen
'84 Ford Sierra XR6
'96 VW Citi Chico 2.0
'85 BMW 518i
'09 VW Citi GTS
'86 VW Citi Sport 1800
'85 BMW 318ı e30
'89 Toyota Corolla 1.6 GL 16V
'82 Alfa Romeo Alfetta 2000l
'85 Alfa Romeo 159i GoldLeaf
'84 VW MK1 GT
ivanjapoeroets
Post by ivanjapoeroets » Fri Jan 26, 2018 9:27 am
I have a 1.8 golf 1 i took it in to replace the waterpump and the timing belt but now it wont start, the destributor is in line but im not sure how to align the pullies on witch the belt runs, please help.. im blank, tried everything my flat head could think of exept trying to align the pullies.. the top pulley has a mark on it but i dont see another mark on the engine like the bottom pulley has, i think that might be the problem but im not sure, pleassseeee
