ks pistons Q?
Dieter
Registered for: 16 years 6 months
Car Model: Amarok V6 Aventura 580nm
ks pistons Q?
Post by Dieter »
How many beating can a 2e/abf ks piston take? If the piston is to be used in a turbo application? and when there is some major milling done to them to clear the valves? I know people have done this, but I just want to make sure.
the area that the red line cover, is to be milled straight out , level with depth of the bowl. (notice the thin wall thickness about 2mm ) will that be fatal? or am I over reacting?
Thanx!
Dieter
2017 Tiguan R 2.0 TSI
2019 Golf GTI MK7.5
1983 Golf GTI MK1 2 door (NZ Spec)
2014 BMW 220i Msport
2010 Golf TSI
2015 Nissan Navara ST-X
2013 Polo 1.4 Manual 6R
2010 Golf 2.0 TDI DSG MK6
2012 Polo TSI 77KW 6R
2002 Citi Golf Chico 1.6i MK1
1997 Citi Golf Chico 2.0 16v Turbo MK1
1978 Golf GL 1100 MK1
BlueBlob
Re: ks pistons Q?
Post by BlueBlob »
Just a note, the 2E (not sure of the ABF) has Mahle pistons as standard. They are semi-forged, and can handle quite a bit of abuse.
k-jetronic rule
Registered for: 17 years 7 months
Car Model: 1994 GOLF CTI
Re: ks pistons Q?
Post by k-jetronic rule »
not all 2E's come with mahle pistons basically any 2.0 long block comes with a selection of either cast or forged crank and either mahle,nural or ks pistons. i have opened 2e's with a cast crank and ks pistons its just luck of the draw, all 60-2 motors accept abf and local long block mp9 2.0l had cast cranks. With pistons you heve to open to see what you have.
Golf CTI"94
2.0 AGG mp9
k-jetronic rule
Re: ks pistons Q?
forgot to ad mahle and nural can take a lot of hammer ks also but not as much as the other two.
Golf CTI"94
2.0 AGG mp9
Dieter
Re: ks pistons Q?
Post by Dieter »
thanx everyone! but will I be able to boost 1.5bar with them after I've milled them out?
2019 Golf GTI MK7.5
2010 Golf TSI
maranou
Registered for: 15 years 4 months
Re: ks pistons Q?
Post by maranou »
I think you gone recess too mutch it needs to be don on a angle and if you can see the recess on pick the arias is second and has small reces and first is a ks with small recess and 3rd nural but with too small reces and last is comby ks with resecc.hte first and 4th piston ks was in my car and did not hit with 7500rpm turbo.
I will be getting my comby pistons back friday and it's been recessed by a pro now so will tack pick and show what's enough,The bigest recess i have seen is on wiseco piston so go read sweetasour post of his car there are pistons in that i believe is wiseco or go see this month's speed and sound pg 194 the second piston from the left
Golf 2l16vT 320kw 520nm
1/4mile @ 12.2 kilarney 2011
800m @ 233km/h
Digit Riaan
Registered for: 18 years 8 months
Re: ks pistons Q?
Post by Digit Riaan »
Just make sure your fueling/timing and assembly is right, then you should not have troubles...and make 100% sure of your compression once you are done, measure it.
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100, '79 Golf LS
Dieter
Re: ks pistons Q?
Post by Dieter »
thanx everyone! I'll make sure of the timing and fueling...
2019 Golf GTI MK7.5
2010 Golf TSI
Dieter
Re: ks pistons Q?
Post by Dieter »
If anyone knows anything about this subject feel free to reply!
Thanx all!
2019 Golf GTI MK7.5
2010 Golf TSI
Dieter
Re: ks pistons Q?
Post by Dieter »
:roll:
2019 Golf GTI MK7.5
2010 Golf TSI
joggiep
Registered for: 20 years 3 months
Membership No: 664
Re: ks pistons Q?
Post by joggiep »
I have Std Pistons and conrods in my Jetta that also only have a small recess milled into the piston so the valves clear.
I have seen and heard of quite a few 2.0 16V Turbo motors that make 300Hp plus on Std pistons and rods, only precausion would be to use ARP bolts on the conrods and get the bottom end balanced. This is what I am getting done as I type this by Sarel on my Jettas motor. I'm hoping to get it running at +- 240Hp on 0.7Bar and to make +- 300Hp on +- 1.2Bar and Race fuel.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
Dieter
Re: ks pistons Q?
Post by Dieter »
Yup, I've already balanced my bottom end, with my current pistons. thanx for the info!
2019 Golf GTI MK7.5
2010 Golf TSI
Coroner
Car Make: VW / Subaru
Car Model: Citi 1600 / 2.0 T
Membership No: 1502
Re: ks pistons Q?
Post by Coroner »
How can one tell the difference between forged and cast pistons? Got a 2l 16v ABF that I’m looking at putting in some Wesico’s
Speed is money......how fast do you want to go?
