Relay for starter
SHAUN
Car Model: 2006 335i
Membership No: 1148
Relay for starter
Postby SHAUN » Fri Dec 05, 2008 8:28 am
How does one wire up a relay for the starter?
Does one use a normal 4 pin relay?
Which wire goes to what pin.
Thanx.
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
Saiendra wrote:I cannot argue with you, you bought a BMW out of motorplan...
JaredS
Car Make: Subaru
Car Model: '05 STI
Membership No: 710
Re: Relay for starter
Postby JaredS » Fri Dec 05, 2008 9:37 am
You can fit an ABF, but you cant wire up a relay???
:wink: :wink: :wink:
http://www.bcae1.com/relays.htm
Car Make: VW, VW, Aprilia
Car Model: Mk2, Mk3, Aprilia Tuono V4
Postby Jetta2 » Fri Dec 05, 2008 9:43 am
I just cut the original wire that goes to the starter solenoid, and did it this way:
I used a normal 4 pin 40Amp relay :wink:
1989 Mk2 Jetta 2.0 8V-T
2013 Aprilia Tuono V4 APRC
pluto
Postby pluto » Fri Dec 05, 2008 9:48 am
Does one need a relay when the ignition is wonky ?? Always wondered why the need pops up for a relay to the starter.. Or is it an anti-theft sort of magodie in some way or the other...
Shiver me Wastegates
Frieling Racing Chip tuning
2013 TT-RS S Tronic
MK1 20VT BAM (Motronic ME 7.5 DBW)
SHAUN
Membership No: 1148
Postby SHAUN » Fri Dec 05, 2008 9:57 am
Thanx ryan.
Postby Jetta2 » Fri Dec 05, 2008 10:04 am
:wink: :wink: :wink: :wink: :wink:
The "original wire to starter" is the one from the ignition switch to the solenoid, cut that one and pop in the relay.
Return to “General Tech Discussions”
Users browsing this forum: No registered users and 47 guests
