Sidedraft Conversion
(DJGyron)
Registered for: 17 years 10 months
Post by (DJGyron) »
Hi Guys!
Here's the deal, I've got a MK2 Jetta CSX 1.8 carb. I've got my freeflow and branch sorted and am making plans to fit a 276 cam on and have the carb head worked a little. I have a set 35 mil webers. I need some info on how to fit the carbs to the head and how to make the conversion work. My carb set up is the same as the pic below:
http://i119.photobucket.com/albums/o129 ... age150.jpg
There are a couple things i need help with like
1. A thermostat like valve on the head that takes in anti freeze from a standard carb inlet manifold, whats that for and does it need to work if running the sidies?
2. The brass thingy on the sidedraft manifold, what fits over there?
3. Do the sidies need earthing?
grego
Car Model: Caddy 2.1 16V ITBS
Membership No: 1518
Re: Sidedraft Conversion
Post by grego »
1. you won't use this with sidies... just get a stopper and hose clamp and block off the coolant pipe that connects to the carb manifold.
2. this is for the vacuum pipe that connects to the carb manifold to supply vacuum assistance for your brakes. it'll work better if you tap fittings into the other 3 runners and connect them all up to the vacuum pipe with t-pieces etc.
3. no they don't
(DJGyron)
Post by (DJGyron) »
Hmmm...ok. And what about fuel regulators and high pressure universal fuel pumps, will i need these? Also, since the sidies are going to the back of the head unlike a crossflow head, the heated air will affect the cars performance somewhat. Any ideas on how to combat the heat issue and cold air inflows into the sidies?
Car Make: VW, Mini, Slowyota
Membership No: 3337
Post by kingr »
you dont need a fuel pressure regulator, but you can add one id you like.
35mm carbs(i think its 38's) are not that big and if the budget is tight ur std mechanical fuel pump will do the job. u run 40's with std pump, no probs!
yeah there is not much space @ the firewall side. welcome to driving a u-flow head. u can run ur own air cool piping from the side of the fender or whateva creative way you can think of, i dont have a air induction @ the moment.
jetting & synconising is very important when setting up sidies! diy as far as you can, but get it tuned properly with correct sync'ing
Kurt #3337
- 10" Mx5 NC2 (main daily)
(DJGyron)
Post by (DJGyron) »
Alright. Just a couple more things I need to sort out. Is there a place in joburg where I can get bolts made for my sidedraft manifold?
Membership No: 3337
Post by kingr »
(DJGyron) wrote:Alright. Just a couple more things I need to sort out. Is there a place in joburg where I can get bolts made for my sidedraft manifold?
std mani bolts if fine
Kurt #3337
Dj lost
Post by Dj lost »
yep....sidies want hi fuel volume....not hi fuel pressure
'07 Ford Bantam
'11 Ford Bantam
WESBANK Modıfıed mk1 replıca
SOLD
'07 Audi A4 B7 1.8T
'06 Polo 1.9tdi 96kw
'07 Audi A3 2.0FSI
'97 VW Citi Chico 2.0i
'71 Leyland Mini 1000 Stationwagen
'84 Ford Sierra XR6
'96 VW Citi Chico 2.0
'85 BMW 518i
'09 VW Citi GTS
'86 VW Citi Sport 1800
'85 BMW 318ı e30
'89 Toyota Corolla 1.6 GL 16V
'82 Alfa Romeo Alfetta 2000l
'85 Alfa Romeo 159i GoldLeaf
'84 VW MK1 GT
JOE_GT
Wheel Whore
Registered for: 15 years 4 months
Car Model: MK1 GT , POLO 9N TDI ,JETTA 5
Post by JOE_GT »
Just a few things to add in....
Step 1 -GET A FIRE EXTINGUISHER!!!
Step 2 -Get proper carb gaskets (Not ''Redline'') they last a month...
Step 3 -Get a proper stud & bobin kit to absorb vibration as this is the reason carbs are alot of work!
Note that the bobin kit prevents the gaskets from wearing out and the kit comes complete with the studs & brass lock-nuts
This was my setup a while back it worked well
PM me if you need a kit :)
Cheers
BillyBob
Car Model: E90 330d M-sport
Post by BillyBob »
Good advice there Joe... well said.
Oh, and get an expert to tune them & set up the chokes correctly - otherwise you'll tire very soon of an engine that revs like a maniac when you get it going, but otherwise in the real world has poor driveability and terrible fuel economy!
Sometimes, we need to remind ourselves of the simplicities of life - you only need two tools: Duct tape and WD-40. If doesn't move and it should - use the WD-40. If it shouldn't move and does - use the duct tape.
Membership No: 3337
Post by kingr »
the pic of that setup is neat :wink:
Kurt #3337
pepa
Post by pepa »
i had a pan on my sidedraughts.Speak to da rite ppl & hav one made up to take care of da heat.
Dj lost
Post by Dj lost »
what ar those in that pic, Solex sidies?
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
Membership No: 3337
Post by kingr »
maybe, not sure. they defintely not weber's
Kurt #3337
Dj lost
Post by Dj lost »
Not weber or dellorto's. Must be solex's
'07 Ford Bantam
'11 Ford Bantam
SOLD
'07 Audi A4 B7 1.8T
'07 Audi A3 2.0FSI
'84 Ford Sierra XR6
'85 BMW 518i
'09 VW Citi GTS
'85 BMW 318ı e30
'84 VW MK1 GT
JOE_GT
Wheel Whore
Post by JOE_GT »
They are indeed -Solex the rare type..lol just buggars to .get spares and service parts for otherwise fairly simple to tune. I know of a clean set if u need some good clean revving carbs.
Membership No: 3337
Post by kingr »
Solex carbs are good, i have driven a mk1 with them on. Goes well & sounds great. Not a weber sound, but you can hear that the "potte" is present
Kurt #3337
Yesh09
Post by Yesh09 »
Howzit gents posting this on behalf of a friend he has a set of sidies on his caddy which he fitted recently but he needs to blank of a water outlet / inlet whatever in may be because he has a different manifold now any advice on how to blank it off few ppl said he should tap the hole if so what size tap and bolt shoud he use?
Robynp500
Post by Robynp500 »
Hi there I'm trying to figure something out... I have a 2.3 vw mk1 that has side draughts on, but I'm afraid to run fuel through to it because I'm running a v6 petrol pump... I'm hoping someone could give me some assistance asap because I'm worried about damaging something... Thanks in advance
PapaJo
Registered for: 14 years
Car Make: VW's
Post by PapaJo »
Robynp500 wrote: Sat Mar 14, 2020 12:49 am Hi there I'm trying to figure something out... I have a 2.3 vw mk1 that has side draughts on, but I'm afraid to run fuel through to it because I'm running a v6 petrol pump... I'm hoping someone could give me some assistance asap because I'm worried about damaging something... Thanks in advance
Find the contact details for RS performance. They are V8 specialist, but have the correct pump and regulator system that give 3 - 4 psi fuel pressure to the sidies. Any other pump and in your case the V6 pump will likely over pressurize the sidies and can cause fuel leaks or damage to the needle and seat and float bowls.
Tell us, how did you get to 2.3L. Fitting 2.3L pistons in a short or long block does not make it a 2.3L. What other supporting mods do you have on that motor?
PapaJo
Car Make: VW's
Post by PapaJo »
PapaJo wrote: Sat Mar 14, 2020 2:18 am
Here is their contact number and address:
51 Rosettenville Rd,
Village Main,
Johannesburg,
2001,
South Africa
Phone: +27 11 334 4342
Caddy anabell
Registered for: 4 years 2 months
Post by Caddy anabell »
I'm just finding out guys I'm doing a sidedraft on one of our cars but I came across a hole on the head which the standard intake fits over with a rubber o-ring what do I there to blank it of?
PapaJo
Car Make: VW's
Post by PapaJo »
Caddy anabell wrote: Mon May 18, 2020 10:10 pm I'm just finding out guys I'm doing a sidedraft on one of our cars but I came across a hole on the head which the standard intake fits over with a rubber o-ring what do I there to blank it of?
Tap that hole and put a bolt in it or Aluminium weld it close.
Yellowshow
Registered for: 4 years 4 months
Post by Yellowshow »
Hi guys, I know this is a late post but any help would be appreciated greatly, I have a 1.8 8v with 276 cam and 40 weber side draughts running on mechanical fuel pump on the block as it is a carb motor, however I'm having a issue with my sidedraughts I cannot get them to idle at all, they Rev up fine but can't idle, they simply die out no matter what any advice for me guys
PapaJo
Car Make: VW's
Post by PapaJo »
Yellowshow wrote: Tue Aug 25, 2020 9:40 pm Hi guys, I know this is a late post but any help would be appreciated greatly, I have a 1.8 8v with 276 cam and 40 weber side draughts running on mechanical fuel pump on the block as it is a carb motor, however I'm having a issue with my sidedraughts I cannot get them to idle at all, they Rev up fine but can't idle, they simply die out no matter what any advice for me guys
First things first.
1. did you check both carbs and confirmed that jet sizes, float levels etc are the same.
2. When fitted, did you fit the correct gaskets between carb flanges and manifold?
3. Did you check that carb butterflies are synchronized and all 4 are open the same amount when in the closed position and when you pull the throttle open that all 4 are moving at the same time?
4. Did you set the air and idle screw the same on all 4 carbs? A good reference starting point is 1 and a 1/4 turn back from fully closed on air idle jet.
These are the basic check you can start with and then work from there.
Yellowshow
Thanks for this, I'll be sure to check everything out, we were not able to get the gaskets between the carb and manifold, and gaskets were made, but now I'm starting to think that was a bad idea, one thing that I did take notice was when the carbs are not sync'd the idle adjusting screw has a gap in between, the screw and lever and when sync'd the gap is taken away, and I did adjust them to 1 turn out on the air fuel mixture,, also I did notice even though they Rev up fine but if I want to take off it stays at a high Rev 3000rpm then I have to switch the car off.
