2nd gear on polo GTI
Jueshen
Post by Jueshen » Thu Oct 30, 2008 3:35 pm
Hi Guys,
i have heard that this is common on the Polo GTI's, when you drive it hard and slam it into second, it makes a horrible sound (almost like its grinding, but its not), does not happen all the time, intermittent problem
any of you experience this?
2003 Audi A4 Avant 1.9TDI
2015 Toyota Corolla D4D
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
icewolf 007
Car Model: VW GTi 35 Edition
Re: 2nd gear on polo GTI
Post by icewolf 007 » Thu Oct 30, 2008 7:09 pm
i had this problem on my jetta 5 tdi, my colleague has it on his golf tdi and another colleague has it on his polo gti. wonder whether that is normal since so many ppl are experiencing this. it annoying though and for me didnt happen with normal driving. only when i hooked it into second
current
2012 VW Golf 6 Gti 35 Edition
2011 Polo Vivo 3door
ex rides
2012 Audi 1.8T SE facelift
2012 Golf 6 Gti
2011 VW polo gti 1.4 dsg
2011 Golf 6 Gti manual
2010 SCIROCCO 2.0 TSI DSG
2008 citi storm 1.4i
2009 golf 6 gti http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=87019
2008 polo tdi highline (114kw/430nm)-sold
2007 jetta5 1.9tdi comfortline (77kw)
2006 opel corsa 1.4 club
2005 polo 1.9tdi sportline (96kw)
2004 polo 1.9tdi 3 door (74kw)
2003 polo 1.6
Fastandfurious
Car Model: Ranger
Membership No: 458
Post by Fastandfurious » Thu Oct 30, 2008 9:27 pm
Jueshen wrote:Hi Guys,
Cable shift gearboxes dont generally like to be slammed into gear, but I've heard of this problem before on the Polo GTi's.
Howie-WP
Membership No: 2033
Post by Howie-WP » Thu Oct 30, 2008 9:36 pm
It is a known problem for the 110kw / cable shift box. As mentioned, they don't like a snap shift, also they recon a decent synthetic oil in the g/box makes a difference. Personally, I'd aim for a more precise shift into second....
WICKED GTI
Post by WICKED GTI » Fri Oct 31, 2008 9:48 am
hey guys, im struggeling with the same bloody problem. with the 30 000 km service, they changed the oil in the gearbox, and it made a huge difference, but after about 5000km it started doing it again, especially when u have a dice and slams it into second gear !. (lost a dice to a opc corsa due to that [email protected]#$%^'ing gearbox) im still not sleeping over it !!, but im taking it back om monday, hopefully it will do the trick !!!!
POLO GTI 17" IMPORTED RIMS, 63MM DE CATTED EXHAUST,KN FILTER,CUSTOM BONNET
116KW ON WHEELS
EX 2007 POLO CLASSIC 1.6 COMF
2004 POLO CLASSIC 1.6
CTI 1.8 276/288 CAM, PULLY, BRANCH,FLOWED HEAD 100 KW
E MAIL : [email protected]
VW MAN
Post by VW MAN » Fri Oct 31, 2008 10:02 am
yeah few guys have had this issue and complained to the dealer....dealer got a new synchro and repalced with no issues now
'14 Golf 7 GTI DSG White
'09 Jetta 5 2.0TSI DSG, T/Red, DP, LED Lighting, HID kit
'12 Golf 6 GTI DSG, CW - Stock
'08 Golf 5 GTI T/Red - Revo2, 216HP, 409NM
'01
Golf 4 GTI - Dimsport, Koni, Powerflow
'08 Golf 5 1.9TDI T/Red
'05 Polo Classic 1.6i (written Off)
'01 Citi Golf Chico 1.4i
'85 Golf 2 GTI - 92.2HP, 138NM - K.A.R
'98 Jetta CLI Exec Full House
'83 Golf Mk1 1300 LS (First car)
HEARTS*
Post by HEARTS* » Fri Oct 31, 2008 12:00 pm
I had the same issue...VW has however got a fix as it is a known problem. I even spoke to the service consultant and he told me they got the fix and manual on how to fix the problem.
The problem is sorted out now, but it left me damaged as I still change as if there is a problem...if you know what I mean.
Ex: '?? Honda Ballade
Ex: '91 MK
Ex: '94 Jetta VR6
Current: '96 MK blues (Mine)
Current: '07 PGTI (SO)
Jueshen
Post by Jueshen » Fri Oct 31, 2008 12:36 pm
Thanks for the responses
took my car for a few runs this morning, and i dont seem to be having the issue anymore, maybe my changing is more accurate, i have no idea!
should i still take it in?, i dont often run it hard
thanks
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
BtN
Post by BtN » Fri Oct 31, 2008 4:00 pm
Jueshen wrote:Thanks for the responses
thanks
bud, my colleage at graaf... has the same problem with his Polo GTi... its currently at VW and they fixing it under Warranty..
not sure exactly what the problem is thou..
it might be a good to have it checked out..
2004 Citi.Com
Roms
Car Model: Polo 9n3 GTI
Membership No: 1270
Post by Roms » Thu Nov 06, 2008 11:14 am
Hi Jueshen,
I've got the same problem on my PGTI...Only seems to happen on when i'm changing on high revs
Car was booked with VW last week to check the gearbox - they changed the gearbox box, but that didnt help.
They say the gearbox needs to be repaired - car is currently with VW.
Seems to be a common problem with the PGTI...
If yur still having hassles rather have it checked out...
CRASHER
Post by CRASHER » Thu Nov 06, 2008 11:25 am
The car is under warranty
Get it fixed as it will get worse in the long run
Because it is in early stage the ring still has enough bite to slow the hub on normal shifts
When you shift hard/fast you need that instant bite and stop to allow smooth engagement of the gear and this is where the ring is not coping.
Its not a big repair get it fixed now as each time you grate it it is causing damage to the dogging teeth and hub etc
Cheers
Crash
Jueshen
Post by Jueshen » Thu Nov 06, 2008 11:33 am
eissh!
thanks guys, well i guess since it's under warranty i reather have it done none now, just such an inconvenience, any specific dealers that know what they are doing? dont wnat to have to take it back again and again or should i take it to the dealer i bought it from?. they better give me a loan car...
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Jueshen
Post by Jueshen » Thu Nov 06, 2008 1:21 pm
sup all,
so i left the office drive slow until the car was warm and then drove like a blerry madman to see if it grinds,
No more grinding!!! i dont know why but i guess its a good thing,
may b it has something to do with the wieght of the car, usually when i do race it i have about quarter tank and as i said befor it intermittently grinds maybe ( 1 out of 8 times) but since the last grind it doesnt happen any more even when the tanks on qaurter or full like it was today
Car is still under warranty till 2011 so i guess i'll have it checked anyway just out of curiousty at the next service, im just scared that theses service agents are going to break something else, while fixing the gearbox, the 1 thing i hate is inconvenience
will keep you all posted
and to the guys still having problesms, how often did u have them? and please let me know what the agents to fix it
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
maranou
Post by maranou » Thu Nov 06, 2008 8:16 pm
1. plolo GTi have 02j box and use castrol bot 150m(is a full syntetic 75w/90 oil comes in 500ml R80 exspensive need 500mlx4=2l)pleas do not use normal 75w/90 becaus oil must last life of the box/car and
2.02j box has a 3part sincro's 2nd gear has a outer sincro with inner ring and inner syncro cost R1100 if one gives [email protected] you will have grind in 2nd
as seen on fig no 16.17.18
Check inner ring for wear by pressing ring onto 2nd gear cone
and measuring gap "a" with feeler gauge. Normal dimension is .03-.05"
(.75-1.25 mm). Wear limit is .01" (.3 mm). See Fig
3.Can some one with pgti pleas put car in first ingage the clutch and release the brake and hanbrake on level surface and rev to limiter and check if car moves forward.What hapens on 2l16v with copper clutch and vr6 pressure plate the pressure plate resonace on high reves and touches the clutch letting car move forward can be same on pgti,but have heard some golf4gti have viscous clutch and not sure what pgti have.
If this hapens then when you in 1st and ingage clutch to select 2nd on high rev it's the same than changing without ingaging clutch :shock:
Golf 2l16vT 320kw 520nm
1/4mile @ 12.2 kilarney 2011
800m @ 233km/h
HuziDada
Post by HuziDada » Thu Nov 06, 2008 10:11 pm
Hey guys
I had this problem...so let me make life a bit easier for you'll :)
You will need to install following parts from VW
02J 2nd gear grind fix ...
[2] - G-005-100-A1 - oil, .5 litr
[1] - 00076 - brake klee
[1] - 02J-311-239-J - synchr hub
[2] - 02J-311-247-C - synchr ring
[1] - 02J-311-261-K - 2nd gear
[1] - AMV-188-200-03 - seal comp
[3] - G-005-100-A1 - oil, .5 litr
Once installed, problem solved!!!
VW Golf MKIV GTI AGU 110KW
FRC @ 1Bar
2.5Inch downpipe and decat exhaust
Forge 007 DV
Samco Boost Pipes
Forge Turbo Inlet Pipe
Motorcade FMIC
BMC CDA
Koni Fully Adjustable Coil overs
157KW 321NM
"The shortest distance between two points is simplicity"
g60 golf
Membership No: 388
Post by g60 golf » Fri Nov 07, 2008 6:33 am
Hi guys.
It is adv to let them chainge syncro ring and gears.
New box can make the same.
They must first check box and see if the gear oil campaign is listed for the car.There is a anf out to say we must first chainge the gear oil to minr. oil from synthetic.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
Jueshen
Post by Jueshen » Fri Nov 07, 2008 10:43 am
shoo, you guys are really clued up hey!
well i will be booking the car in on monday, i had it grind this morning!!
i just wish they could just change all the stuff that Huzidada had done, but they have to change the oild first apparently!
oh well, i guess procedures is procedure, i know i will take it back a second time round, but as long as it gest fixed
thanks all, really appreciate it
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Jueshen
Post by Jueshen » Fri Nov 07, 2008 11:55 am
eish guys hows this for peace of mind
Went to VW Jan Smuts, explained the problem to them, and they said they have never heard of that problem before, but will get sum1 to check it out
its like going in for heart surgery and the guy doesent know what he's looking for!!! :twisted:
eventually made a booking at hatfield VW (bryanston) were i spoke to Morne ad he assured me they know what to do, but they most probably will change the oil first, depends if there is any damage in the box or not, and will test
Will keep u guys posted, taking her in monday morning
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Roms
Membership No: 1270
Post by Roms » Fri Nov 14, 2008 9:03 am
Hi Jueshen,
To put yur mind at ease - I got my PGTI from VW Hatfield(Big Thanks to Morne and Andrew) yesterday.
Had the same problem as yur PGTI...The car is now sorted :lol:
The car some how feels much stronger - nothing like when I 1st drove it out of the showroom.
Its like a little beast now :twisted:
Any stock G5 GTI wanna take me on :mrgreen:
Jueshen
Post by Jueshen » Fri Nov 14, 2008 4:09 pm
Thanks Roms,
they changed the G Box oil on mine, havent had any issues yet. what did they do on urs??
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Burner1144
Post by Burner1144 » Fri Nov 14, 2008 5:24 pm
Hi Guys,
While we on the subject of gearboxes and with all the gearbox gurus watching this thread, i have a small issue thats bugging me.
Its on my 04 132kw Golf (6spd box). Changing from higher gears to to 3rd, upon releasing the clutch there is a low pitch whine when the car slows on 3rd, and this is doing slow speeds. It only happens when the car is still warming up and only happens when releasing the clutch. It engages 100% upshifting and downshifting, and when the car is up to temp the whine goes away.
Anyone with any ideas. The car is coming up to its 90k service, maybe i should just ask the vw tech's to change the oil in the box 1st.
Appologies if i jacked the thread.
2005 Subaru STi
2005 Golf 5 GTi
2004 Golf 4 GTi R
2002 Golf 4 GTi
g60 golf
Membership No: 388
Post by g60 golf » Fri Nov 14, 2008 9:36 pm
I have seen one or two boxs do that,[6spd]
Get it looked at as it will get worse and damages box.R16800.00 for recon and R33000.00 new.
Dealer prices.
G60 16V GOLF
Burner1144
Post by Burner1144 » Sat Nov 15, 2008 3:58 pm
Dealer prices.
OMG :shock:
Ill def point it out to the vw guys when i take the cab in.
2005 Subaru STi
2005 Golf 5 GTi
2004 Golf 4 GTi R
2002 Golf 4 GTi
HuziDada
Post by HuziDada » Sat Nov 15, 2008 10:10 pm
Golf 4 GTI 132kw 6spd fix
02M 2nd gear grind fix ...
[1] - 02J-311-251-J 1st gear
[1] - 02J-311-261-L 2nd gear
[1] - 02J-311-239-J synchr hub
[2] - 02J-311-247-C synchr rng
[2] - 02J-311-277-A synch ring
[2] - 02J-311-279 Outer ring
[1] - 02A-311-531-K reversgear
[2] - G-005-000 Oil-1 litr
FRC @ 1Bar
Forge 007 DV
Samco Boost Pipes
Motorcade FMIC
BMC CDA
157KW 321NM
Jueshen
Post by Jueshen » Mon Nov 17, 2008 5:24 pm
shoo lots of G Box issues! anyhoo looks like the oil change on my G Box did not fix the issue---still grates!, made a booking for next week with Andrew... +-3 days, gonna miss her, BTW after looking at alot of Dyno results on worked PGTI's and stock ones, the stock pushes out +- 116 KW and 240 NM, can any 1 agree with me on that one? :?
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
