1800 jetta 2
Rayzer69
1800 jetta 2
Post by Rayzer69 » Wed Oct 29, 2008 5:33 pm
Hi guys,
Got a 1989 jetta 2 clx carb 1800, used to be auto, have made it manual.
clutch is a bit stiff!
and I dont feel like I'm getting enough top speed!
Is that timing?
what mods can I do to get some some real power,
got 63 mil free flow.
branches
cone filter.
would like to go more valves.
would like to port and polish.
Would a different gearbox help?
What sort of cams can i get!
reliability is most important tho!
Donavan
Re: 1800 jetta 2
Post by Donavan » Wed Oct 29, 2008 5:51 pm
Ask Ryan maybe? :twisted: :twisted: :twisted: :twisted: :twisted: :twisted:
Audi A3 1.8t 20V
http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=33370
GolfMad
Car Make: Nissan
Car Model: Terrano 2.7 TDi 4x4
Re: 1800 jetta 2
Post by GolfMad » Wed Oct 29, 2008 5:53 pm
I guess it would depend on your budget, but start with a proper billit cam, say a 268 or 272 degree, freeflow system of 57mm, 4-2-1 branches, then you can look at going Fuel Injection, that will add a nice amount of power. 8)
Current Mk3 Gti Sold.
Jy kan met 'n Nissan (soms)
VroetelTrok - 1974 VW Baywindow Bus
Rayzer69
Re: 1800 jetta 2
Post by Rayzer69 » Wed Oct 29, 2008 6:44 pm
got 4-2-1 wilcats
got freeflow!
maybe its too big?
where can I get a good reliable cam and what will that cost ?
what about fitting it?
Rayzer69
Re: 1800 jetta 2
Post by Rayzer69 » Wed Oct 29, 2008 7:10 pm
How much will it cost to go fuel injected?
What does it involve?
nedflanders
Re: 1800 jetta 2
Post by nedflanders » Thu Oct 30, 2008 7:57 am
63mm freeflow on a fairly stock 1800 carb is WAY too big. Run a straight 50mm, or, if you plan further mods, either a progressive 50:57mm or even a 57mm setup. The bigger you go the less bottom-end you will have.
Estas cams available from Nellis @ Sporcam: 021-9499914, don't go wilder than 276.
Stiff clutch action could be the cable or the pressure plate. Did you use new or 2nd hand items?
What kind of top speed are you getting, anyway?
Rayzer69
Re: 1800 jetta 2
Post by Rayzer69 » Thu Oct 30, 2008 5:04 pm
We sourced out most of the parts from a clx 1800 manual.
clutch and pressure plate is new.
cable is new.
flywheel is new.
Getting about 170 top speed.
also CV joints seem to be getting loose all the time!
Rayzer69
Re: 1800 jetta 2
Post by Rayzer69 » Thu Feb 12, 2009 10:11 am
I am in a project now gonna make it injected MP9!
Looking for a cam still!
need dgg gearbox and 2e block.
Will wait and see what happens then?
GolfMad
Car Make: Nissan
Re: 1800 jetta 2
Post by GolfMad » Thu Feb 12, 2009 10:34 am
Depending on your budget, go for a 2liter (2e or ABF) with MP9 Fi, nice 276 cam, then you can use the 63mm FF zorst !
