FAQ and Using the SEARCH function
Posted: Wed Mar 05, 2008 10:19 am
by RoadHaWg
Guys just a reminder.
A lot of the questions asked here have been discussed in depth before. Just because it is your first time thinking about a problem or solution, doesnt mean it is everyones first time.
To avoid frustration and re-posts PLEASE use the search function to try find what you are looking for before starting a new thread!
You may get flashed with this .gif which shows where the search function is:
Click on 'Search'
In the search page type what you are looking for and on the left select which section this will fall under (Technical, ICE etc)
Selecting "Search for all Terms" narrows the search down a lot so try that.
If you still cannot find the info you need please check the FAQ section or then feel free to make a post in the RELEVANT FORUM.
Thanks.
Re: FAQ and Using the SEARCH function
Posted: Thu Oct 16, 2008 9:29 pm
by kingr
The search function is down
Posted: Sun Oct 19, 2008 1:32 pm
by EX-DOHCTOR
kingr wrote:The search function is down
Posted: Thu Feb 26, 2009 12:16 pm
by dood786
Posted: Tue Sep 22, 2009 12:00 pm
by 4ePikanini
no excuse
http://vwvortexsearch.webs.com
Posted: Tue Mar 22, 2011 12:53 pm
by GTiDon
Does the search look into old history? I cant seem to find stuff thats a couple of years old
Posted: Wed Aug 31, 2011 4:28 pm
by MeanTdi
gtidon wrote:Does the search look into old history? I cant seem to find stuff thats a couple of years old
Yes.
Posted: Mon Mar 26, 2012 12:39 pm
by GTiDon
Tried again still no results
Posted: Mon Mar 26, 2012 12:41 pm
by Puni
Mine works fine... Sometimes doesnt work. Then I log out and in.
Posted: Sat May 19, 2012 1:27 pm
by Wit Ark
I am not winning with the search function, trying to find a oldish post i made in the rides section that i would like to update, but i am not going to browse through 1000+ previous posts i made to find 1, can anyone assist?
Posted: Sat Feb 21, 2015 11:04 am
by MISG7
Can anyone tell me why the golf 7 Gti u angel eyes only has one working while the golf 7 R has both working?
Posted: Sat Feb 21, 2015 11:41 am
by chucker02
Another lost kid loose on the forum
Posted: Fri Aug 21, 2015 2:21 pm
by Krayzie
MISG7 wrote:Can anyone tell me why the golf 7 Gti u angel eyes only has one working while the golf 7 R has both working?
Lmao,really?
Posted: Fri Aug 21, 2015 2:39 pm
by Stompie
How do i reply to posts?
Posted: Sun Mar 02, 2025 1:50 pm
by Anton5
Hi all.
When I bridge out the 3 wire "triangular" plug wires that come from the radiator thermostat switch on my 2005 VW Polo 2.0L petrol 9N with a BBX motor, only 1 of the relays in the "black box" (the rectangular box that's mounted on the chassis almost level with the thermostat switch of the radiator)activate. Is this normal? In normal running conditions, the cooling fans only come on when the AC is switched on, hence car tends to overheat.
Any advice would be appreciated.
Many thanks Anton
