Common VR6 faults?
Common VR6 faults?
Post by panic-mechanic » Wed Jan 09, 2008 2:43 pm
Please constribute if you had owned one. If you had failures as in my list please indicate and others then we expand the list.
I'm going to try and make it VR specific so common to all mk3 issues I'm going to leave or make a separate list here.
list of really common faults I can think of.
1) Thermostat housing cracks/leaks after around 150k km.
2) thermosatat failure.
3) recirculating water pump failure.
4) timing chain Guides wear - drops a valve in some cases
5) breather pipe rots.
6) Abs faults.
7 ) coil pack failure
8 ) HT lead failure - partly due to abuse in not using the correct tool (which should be clipped to your bonnet stand)
9) brake master cylinder failure
10) water pipes/pump failure.
11) maf failure
12) clutch pedal clip?
13) Lambda sensor. I think this will b less common now that we run unleaded. Leaded fuel is known to kill these.
14) throttle body idle motor failure.
15) seems radiator is becoming a problem on the older ones.
16) Serpentine belt tensioner ( Next time buy the one from Goldwagen - it's metal)
That's about the list I can think of.
Mk3 - not only VR specific.
1) heater radiator
2) Window winder issue
3) aircon relay pack under water bottle.
4) Cubby hole handle
5) control arm rubbers.
Last edited by panic-mechanic on Thu Jan 10, 2008 11:39 am, edited 8 times in total.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
Post by Rabbit222 » Wed Jan 09, 2008 2:50 pm
I had a gearbox issue on mine. Car would jump out of 2nd gear into neutral when accelerating.
Post by panic-mechanic » Wed Jan 09, 2008 2:52 pm
Never seen it before - won't call it common..
'09 Audi Q5 3l tdi
MeanTdi
The Imposer Mod-whore-rator
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Post by MeanTdi » Wed Jan 09, 2008 2:53 pm
9) HT lead cable failure (mainly due to been pulled out by cable instead of using correct tool to remove them at the connector).
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Post by panic-mechanic » Wed Jan 09, 2008 2:57 pm
Yeah I was considering that as an item for the list but felt it almost a wer and tear - But yes really common. Will add.
'09 Audi Q5 3l tdi
VeeRar6ix
Post by VeeRar6ix » Wed Jan 09, 2008 3:01 pm
*Delicate brake master cylinders
*Oxygen sensors (not only VR6)
*MAF goes into early retirement
*Car revs irretically and just dies
*Rubber pulleys that costs a fortune but look like the dogs breakfast after 12 months
*Engine temp sensors
*2nd stage speed radiator fan never kicks in
2008 Velociti 1.4i
1995 Jetta 12v VR6 Turbo 6 speed 4WD
(Ex headache)
1995 Jetta 24v VR6 Turbo
Turbo lag: the number of seconds the guy in the other car thinks he is winning...
VeeRar6ix
Post by VeeRar6ix » Wed Jan 09, 2008 3:06 pm
*fuel feed and return pipes that crack and leak (age/heat)
2008 Velociti 1.4i
(Ex headache)
Post by panic-mechanic » Wed Jan 09, 2008 3:07 pm
Yikes - out of your list - only 1 common but it's mainly due to the use of leaded. Should be less now - Oxygen sensor.
Leaky fuel lines - simply age. Not a VR only item.
'09 Audi Q5 3l tdi
PUNK
Post by PUNK » Wed Jan 09, 2008 3:21 pm
water pump failure, engine mount failure, water pipe failure...
plastic clip attached to clutch pedal breaking causing clutch pedal 2 disappear into the firewall (strange thing 2 happen bt has happened to myself and boyracer-wp)
Current: 1996 Mk3 Gti 8v / Cloth Recaro's / mk4 bits / 9J Schmidt Modernlines / KW V1 coils
Ex: 1997 Golf VR6 - H&R's / 57mm zorst / mk4 gti bits / (194 bhp / 244 nm)
Ex: 2003 Mk1 1400
Super Stu
Car Model: B7 A4 3.0TDI Avant Quattro
Membership No: 274
Post by Super Stu » Wed Jan 09, 2008 3:23 pm
Most common VR6 fault. Faulty fuel gauge. No matter how many miles on the clock or the age, the fuel gauge has a short in it that causes it to head for the 0 mark at warp speed 19 each and every time full throttle is applied.
Still miss my VR........................
2007 - Audi B7 A4 3.0TDi Avant Quattro Tiptronic
2005 - Porsche 911 (997.1) Carrera S
VW Challenge C 51
Revolution Racing Spanner boy
THE GAME
Wheel Hoarder
Car Make: VW / BMW
Car Model: Golf VR6
Post by THE GAME » Wed Jan 09, 2008 3:29 pm
I had so far probs with
MAF,
Water Pump,
Window mechanism,
Water Pipe,
Coilpack
Brake master Cylinder
HT leads,
Lamda Sensor....
Otherwise im enjoying it........
"HaTe iT oR LoVe It"
2001 E39 M5 Antracite
1997 Golf VR6 White
1992 E30 325i Silver
2011 BMW 320d M Sport White(Yes another White one)
1991 E30 318i coupe Red
2011 BMW 320d Msport
2004 323 Mazda (Daily)
Golf 5 GTI DSG United Grey
2005 318i E46 Individual
2001 Polo Playa 1.6
200i 16v Dohc Mazda
2004 318i E46 Special Edition
2002 Polo Playa 1.6s
Post by panic-mechanic » Wed Jan 09, 2008 3:35 pm
I must have been lucky. Will add the others. Brake master - strange.
'09 Audi Q5 3l tdi
nhunter
Post by nhunter » Wed Jan 09, 2008 3:38 pm
Idle motor on TB?
'05 VW Passat 2.0 TDI Highline
'06 Toyota Yaris T3
:( Ex '96 Golf MK3 VR6 137hp and 185nm @ KAR
* Shaved front * Koni * Eibach * SMT6D * 268's * Flowed Head * VF Engineering * Recaro * H&R
Post by panic-mechanic » Wed Jan 09, 2008 3:41 pm
most - post 96 OBDII same as mp9.
'09 Audi Q5 3l tdi
MoCTi
Post by MoCTi » Wed Jan 09, 2008 3:43 pm
heater radiator
radiator went around the top hose (rust)
Jetta VR6 (wildfire) AKA:2 hot 2 handle
Honda RVF 400R
2dr GolfII GTi 16V
GolfII CSL (carb job) [email protected]$$ car(not for long)
Jetta 3 CLi 98 spec (never say DIE)
CTi - underdog
128kw
Car Model: Polo TDi
Post by 128kw » Wed Jan 09, 2008 3:47 pm
Heater radiator
Aircon radiator relay/control unit (under the water bottle)
Clutch Slave cylinder
Hers:
05' TDi Sportline White - New Spec, mudflaps
06' Velo 1.4i Ice White - Mk1 mudflaps, recess plates, detrumpetted airbox, KnN Flatbed, Mk2 GTi Spoiler - Insurance Write Off 11/08/2013
98' Golf 3 VR6 White aka Flook - 40mm drop all round, 205/50 SZ80's, VR6 mudflaps, MK3 Spoiler, Webasto inbuilt tilt and slide
04' Golf Life 1.6i White - Sold For the VR
Post by panic-mechanic » Wed Jan 09, 2008 3:50 pm
clutch slave is simply wear and tear - every car with a hydraulic clutch will have it at some point. Same with heater radiator - mk2/3 common issue - not VR specific. Same with aircon relay switches. Mk3 issue - not VR specific. Actually so is the window winder so I really should pull that from the list.
'09 Audi Q5 3l tdi
SpikePCR
Post by SpikePCR » Wed Jan 09, 2008 3:57 pm
No problem with mine yet. But will let you guys know if anything happens
THE GAME
Wheel Hoarder
Car Make: VW / BMW
Car Model: Golf VR6
Post by THE GAME » Wed Jan 09, 2008 4:06 pm
SpikePCR wrote:No problem with mine yet. But will let you guys know if anything happens
Don't talk so soon,
8)
Touch wood your car did'nt start as yet, u damm lucky for now....heheheh
1997 Golf VR6 White
2001 Polo Playa 1.6
200i 16v Dohc Mazda
SpikePCR
Post by SpikePCR » Wed Jan 09, 2008 4:09 pm
Don't talk so soon,
8)
Hope so too .But she only has 82000km on the clock.The previous owner has her well maintained.She may be up for sale soon.
VR - G
Car Model: MK3 VR6 Golf
Post by VR - G » Wed Jan 09, 2008 7:58 pm
Eish!! Where does one start?
- ABS sensors
- Driver's Window winder
- Now I have a water leak coming from somewhere above/ around the oil cooler
- O2 Sensor
- Thermostat housing
- timing chain Guides
- coil pack failure
But I still love the car!!! :P
1996 Golf VR6 - Now with 17" Porsche Cup 3 Replicas
128kw
Car Model: Polo TDi
Post by 128kw » Thu Jan 10, 2008 7:25 am
panic-mechanic wrote:clutch slave is simply wear and tear - every car with a hydraulic clutch will have it at some point. Same with heater radiator - mk2/3 common issue - not VR specific. Same with aircon relay switches. Mk3 issue - not VR specific. Actually so is the window winder so I really should pull that from the list.
Didn't see this at the bottom your original post :oops:
Hers:
Wakie
Car Model: 2007 Jetta 2.0FSi
Post by Wakie » Thu Jan 10, 2008 7:36 am
Mines still top notch but things I've had problems with:
Window winders on all except the driver's
ABS light coming on for no reason. When they checked it for errors there was no ABS error
CV's (obvious reasons)
One new thing I recently started experiencing is when I fill petrol at certain garages she goes fine and then when I want to floor her it's like there's no power. The minute I gently accelerate she goes normally. Could it be something with the petrol at those certain garages or has someone experienced this before?
2016 Polo TSSSSi
1994 Jetta Virus GONE
2007 Audi A3 2.0FSi GONE
2008 Jetta 2.0TDi Sportline GONE
1992 Caravelle 2.5 GONE
2005 Polo 1.9TDI Sportline SOLD
2005 Citi 1.4 SOLD
2007 Velociti 1.4i SOLD
1984 Caddy 2.0 SOLD
1996 VR6 SOLD
1998 Polo Classic 1.8
Car Model: MK5 GTi DSG
Post by [email protected] » Thu Jan 10, 2008 8:50 am
Parts i had to replace since owning my VR6 for the past 2,5years (and some reasons why
Waterpump
HT-Leads
Lambda sensor
Coolant-temp sensor
Radiator
Airflow-Meter
ECU-Relay
Wheel-bearings
CV's
New Key
Ignition barrel
(Cant think of anything else atm...)
Last edited by [email protected] on Thu Jan 10, 2008 10:54 am, edited 1 time in total.
REVZ Performance
Tel: 0832609721
Mail: [email protected]
His: 1994 Jetta VR6 / 2014 Ford Kuga 1.6 Ecoboost
Her's: 2005 MK5 GTi
Ex 2003 S40 T4 (SOLD)
Ex: 1999 S40 T4 (DEAD)
Ex: 1996 Golf VR6 (SOLD)
http://www.facebook.com/pages/Revo-Tech ... 4385566484
wurm6
Post by wurm6 » Thu Jan 10, 2008 10:46 am
alll things i have had problems with my car
1. having widow problems( windows will only operate when driver is open)???? :?: :?:
2. coil pack
3. thermostat housing
4.ht leads
5.lambda sensor
6.maf
7.speedo not working goes up to 40 and stays there
8.front oil engine mount
9.fuel gauge.(i hate the fact that they never gave mk3. a reserve light)
10.cubby handle broke twice already
11.rubbers on the control arm
12 pulley bearings.that adjustable pulley next to the airbox
96 VR6
02 GTI
06 VELO
