ALL BOSCH MP9 RELATED INFORATION
Posted: Wed Jan 01, 2025 5:17 am
Hello first off PLEASE DO NOT REPLY if you do not have any reliable or validated information. This is for imperical data only. NO opinions or anacdotal experiences. This is a page for proof and numbers. Create your own page if you dont agree with the above. I will delete any info that is not relevant or truly helpful.
I want to create a page where all the correct and relevant information is gathered with regards to the Bosch MP9 Fuel injection system as it came from the factory. No funny frankenstein conversions. The only conversions I want to discuss is converting imported engines such as Japanese imported 2E, ADY and AGG engines from the Digifant or Siemens System to Bosch MP9.
I have purchased an imported a 2.0 8v AGG engine (Japan Import) which I want to install into my VW T3 Syncro. The engine comes without a ECU so I needed to check how one can use the AGG engine in SA without needing to import parts. This is what I have found out so far and I will be adding to the list as group members post info. For my application I will also require a new wiring loom as my engine did not come with any wiring.
There are some key questions I have:
1. What components are needed for a Bosch MP9 System to work as intended?
2. How is the MP9 System Different from other fuel injection systems found in other regions? For example the Golf Mk3 2.0 GTI came with either a Bosch Digifant or Siemens Simos system which is used in the rest of the world. Why did VW SA develop the MP9? Is it really better or just different?
What is the MP9 System?
The Bosch MP9 (Motronic MP9) is an engine management system introduced in the mid-1990s, only used in South African Volkswagen models like the Citi Golf, Polo 6N, and Golf Mk3. It integrates fuel injection and ignition control, relying on a MAP sensor instead of a MAF sensor to simplify the system.
The components:
1. ECU - (Aka Computer Box)
ECU Part Numbers:
2.0 Engines - 0 261 204 026 (1 HS 906 258)
1.8 Engines - 0 261 204 156 (6K0 906 258 B)
1.6 Engines - 0 261 204 157 (6KS 906 258B)
1.4 Engines - 0 261 204 959 (1 7S 906 258 C)
**Please let me know if there are any other part numbers, but post pictures of the ECU please**
Note: ECU's are often flashed to be able to be used on different engines. A 1.4 ECU can be flashed to a 2.0 fuel and ignition Map. But I am very careful when it comes to ECU's that have been tampered with. You have no idea what the guys felt like uploading or changing and if they have been correctly flashed with OEM maps. Use your common sense and buy from people with a good reputation and who are known in the community. Buy from people you trust. Personally I chose to buy good x2 and original 2.0 ECUs from a reputable buyer that have not been flashed, only the immobilizer has been removed. They cost more but I am sure it will be worth it.
Immobilizer: The immobilizer in the context of the Bosch MP9 engine management system is an anti-theft feature designed to prevent the engine from starting unless a correctly coded key is present. It is a part of Volkswagen's vehicle security system. They can be switched off on the ECU by someone who knows what they are doing. Boxes where the immobilizer is turned off are commonly sold as "Open Box" whereas with immobilizer they are sold as "Closed Box"
2. Distributor
Requires a distributor with a 4-gap rotor plate, providing the ECU with timing signals.
MAP Sensor (Manifold Absolute Pressure)
Function: Measures intake manifold pressure to assist in determining the optimal air-fuel mixture for combustion.
Part Number : 0 261 230 011 (I am not sure if this is the correct number)
3. Idle Control
Function:
1. Idle Speed Regulation: The integrated system adjusts the throttle position to maintain a stable engine idle speed under varying conditions, such as changes in engine load or temperature.
2. Cold Start Enhancement: During engine warm-up, it increases the idle speed to ensure smooth operation until the engine reaches optimal operating temperature.
3. Load Compensation: It compensates for additional loads from accessories like air conditioning or power steering by adjusting the throttle position to maintain consistent idle speed.
Part Number: Unknown. Info appreciated.
4. Throttle Position Sensor (TPS)
Function:
1. Throttle Position Monitoring: The TPS continuously measures the position of the throttle plate, providing real-time data to the Engine Control Unit (ECU) about how far the throttle is open.
2. Fuel Injection and Ignition Timing: Based on the throttle position data, the ECU adjusts fuel injection quantities and ignition timing to optimize engine performance, fuel efficiency, and emissions.
3. Acceleration and Deceleration Response: The TPS enables the ECU to detect rapid changes in throttle position, allowing for immediate adjustments to the air-fuel mixture during acceleration or deceleration.
5. Fuel Injectors:
Part number: Unknown. Info appreciated
6. Intake Manifold
There seem to be differences in the intake manifold when it comes to the engines available in the rest of the world. The reason for that might be because the Bosch MP9 ECU works off of a MAP (Manifold Absolute Pressure) instead of a MAF (Mass Air Flow) as well as a TPS (Throttle Position Sensor). I am not sure if the intake ports match up exactly with imported engines. Some people say it is not an exact match, if you have evidence in terms of pictures please post them below comparing the manifolds directly.
Please let me know if you have any part numbers for the manifolds. Maybe there are also different manifolds for 1.4, 1.6, 1.8 and 2.0 engines, each with a different diameter port. The only way it to compare part numbers and measure the diameter.
There are more parts like the knock sensor, temp sensors, crank position sensors, oxygen (o2) sensors and some more which should be stardard across all of the engines regardless of the region.
Differences between the Bosch Digifant, Bosch MP9 and Siemens Simon fuel injetion Systems.
The Bosch MP9, Siemens Simos, and Volkswagen Digifant systems represent three distinct approaches to engine management in various Volkswagen models over different eras. Each system reflects technological advancements, market needs, and regulatory requirements that shaped their design and deployment.
The Bosch MP9 system, introduced in the mid-1990s, was primarily used in South African models like the Citi Golf, Polo 6N, and Golf Mk3. It was designed for simplicity, reliability, and adaptability to local conditions, such as variable fuel quality. The MP9 utilizes a Manifold Absolute Pressure (MAP) sensor instead of a Mass Air Flow (MAF) sensor. The system integrates key components, such as a throttle body with an idle control valve and a throttle position sensor. The MP9 also includes a knock sensor, enabling adjustments to ignition timing for better engine protection and performance.
In contrast, the Siemens Simos system, introduced in the mid-1990s and used predominantly in Europe, represents a more advanced approach. It integrates both MAP for precise air intake measurement and employs sequential multi-point fuel injection for enhanced efficiency and performance. The Simos system features adaptive learning capabilities, allowing it to optimize engine parameters based on driving conditions. This system was commonly found in models like the Golf Mk3 with 1.6L and 2.0L engines (ADY and AGG) and was tailored to meet stricter European emissions standards while delivering improved drivability and responsiveness.
The Volkswagen Digifant system, an earlier iteration introduced in the late 1980s, marked a transition from mechanical to digital fuel injection. Widely used in models such as the Golf Mk2 and early Mk3, as well as the Jetta and Passat, it combines basic digital fuel injection with ignition control. The Digifant system typically relies on a MAF sensor for air measurement and uses an external idle stabilization valve (ISV) for idle control. While effective for its time, it lacks the advanced features of MP9 and Simos, making it less efficient and adaptable to modern demands.
Is the MP9 System Better?
Well.. Thats not for me to say. I do not have enough experience with these engine management systems. I do suspect that the Bosch MP9 system is a sort of compromise. Something in between Digifant and Siemens Simos. I believe that VW SA had to create a reliable solution tailored for the South African emerging markets, balancing cost, simplicity, and performance. Any input here will be appreciated.
Here are some additional part numbers for those interested:
Siemens Simos ECU 2.0 8v (Such as AGG engine) : 037 906 025 R (5WP4 256)
Digitant ECU 2.0 8v (2E engine) : 037 906 022 ED ( 0 261 200 328)
I will update this main text based on answers posted below. I will only include and use information from trusted sources and none of the "a friend of a friend said that the MP9 makes 50% more power nonsense"
The components:
ECU Part Numbers:
2. Distributor
3. Idle Control
Function:
Function:
5. Fuel Injectors:
6. Intake Manifold
