Hi guys.
I'm looking for some advice on a diesel pump upgrade.
I'm running the Ahf motor with a slightly bigger turbo, but now the lag is so bad it shuts the motor off. Due to the pump not giving enough fuel. The actuator has been turned down a lot. Now it drives nice. Maybe you guys know of an Audi or Beetle that might have used a bigger pump.
Thanks in advance.
Dar
Jetta 4 diesel pump advice
- Registered for: 4 years 4 months
- Car Model: Jetta 4 1.9Tdi
3.3L per 100km
What more do you want
Re: Jetta 4 diesel pump advice
I don't think it's quite possible for lag to shut off an engine. Esp on a diesel, it will diesel knock like crazy if it's very bad. U may have another issue.
Unless u mixed up the turbo vacuum line with the anti shudder valve.
Just so everybody is on the same page, what's the original turbo and what turbo did u fit?
Is the original a wastegated turbo and u fitted a vnt?
Hi
I can't really say what the original turbo was. It's an import motor, but I'm currently running the GT1756 Hybrid.
I have a mechanical diesel pump in and the tuner at the time suggested a fueling issue. Think it's a waste gated turbo.
Strangest thing is my car don't leave a black exhaust line on the floor as it used to when driving.
3.3L per 100km
Well if there isn't enough fuel there's not gonna be any black smoke.
Again fueling is dependent on how much air enters the engine, If the maf is reading incorrectly it's not gonna give u fuel or boost.
And on the vnt turbos, u don't adjust boost levels by adjusting the actuator, u just messed up the settings of the turbo by doing that.
First thing I would recommend is verify vacuum pipes. The only thing that makes sense of the engine shutting off when trying to get into boost is the turbo actuator line is swapped with the asv. So as soon as the n75 requests boost, it's closing the asv instead of operating the actuator.
Once that is confirmed then u can look into fueling. Maf sensors give issues now and again, unplug it and check if it drives better.
Thanks brother. Much appreciated. Starting with the Maf. They did mention it could be faulty.
3.3L per 100km
Next time when revising the software, get the tuner to delete the maf. One less thing to worry about it.
