I need some info on battrickery.
I have disabled the start stop function on the 7R. Logic in the battery world tells me that I dont need all the CCAs that a Start stop function requires having it enabled hence going normal Gti battery.
Thus, I want to install a 7 Gti battery which is cheaper because the car will not switch off again when stopping etc. If there is no saving a few bucks difference between the two then just get the start stop battery.
Any suggestions from the battery gurus? Will I run into any issues doing this?
Many thanks!
Golf7 R vs Golf7 Gti battery
- Neuk
- Treasurer
- Membership No: 806
Re: Golf7 R vs Golf7 Gti battery
I wouldn't think that CCA is that important for stop/start, what is more important is the type of battery like AGM or the capacity of the battery in Ah.
- mk2-phreak
Yeah the battery capacity (ah) is important, but the CCA is also important for cold weather starts. Just because you can get away with a cheaper battery, doesn't mean you won't run into issues during winter
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
I am curious to know, what is the price difference between the two batteries?Dale wrote: ↑Mon Nov 13, 2023 10:28 am I need some info on battrickery.
Many thanks!
