Good day guys
Is it possible to fit a 6 speed gearbox to a Polo 1.6 2005 model?
I find i get to 5th and am doing around 4000rpm at 125km/hr or so and another gear would be great to drop the engine revs. The 6th gear would be a real overdrive gear - i know i might need to gear down for hills!
cheers!
Allan
6 Speed Gearbox
- Registered for: 5 months
- Car Make: VW 2005 Polo 1.6
- Registered for: 21 years 3 months
- Car Model: 2017 Cross Polo 1.2 TSI
Re: 6 Speed Gearbox
viewtopic.php?t=212121
I have a 6-speed in my 6C 1.2TSI. It is nice, but yes I feel like I'm never in the right gear.
Uphill? Yeah, nah, that's a 3 gear downshift not just 1.
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
1989 Audi 500 turbo (the end. finally.)
- mk2-phreak
Re: 6 Speed Gearbox
Possible yes, worth it on a 1.6 N/A, probably not
Re: 6 Speed Gearbox
You will do better with a slightly longer final drive ratio.
If you research which gearbox from your series of Polo has the better ratio to suit your requirements, that is the route you go.
6spd will require modification to fit WRT the mountings and starter etc.
Not only that if the ratios are not suited to your engine kW output you will spend your drive stirring the pot so much people will think you are left-handed. You need much torque to use more gears.
Sent from my 2107113SG using Tapatalk
Re: 6 Speed Gearbox
