temperature gauge rising but my car is not overheating?
Mike2
Registered for: 6 years 1 month
Car Model: Polo 1.2 TSI
Post by Mike2 »
Hey good day my VW guys hope everything is good your side.
I would like to know whats the issue with my car I'm driving a VW polo tsi 1.2 2015. Why is my temperature gauge rising but my car is not overheating?
When ever I go on a steep uphill such as salowrys pass to Grabouw or houw Hoek pass than temperature gauge rise over 90 degrees till in the red but car is not overheating. when going downhill my car goes back to normal temperature
New waterpump was fitted last year September
Reason for new waterpump old pump was leaking coolant car never overheated before only overheated when I forgot to put coolant bottle cap back.
Please guys would like to know what's wrong your help will be much appreciated please please guys.
Mikie98
Registered for: 2 years 5 months
Re: temperature gauge rising but my car is not overheating?
Post by Mikie98 »
I have tried everything in the book on mine and also the same issue I hope it isn’t anything major that needs to be done.
If I find anything out I will let you know. I know this isn’t helpful but at least we not alone.
Does your coolant warning also go off?
Mike2
Post by Mike2 »
Hi mikie when the heat gauge only goes all the way down to 130 degrees than the coolant warning light will beep when I'm on a straight light will go away and everything back to normal again
I'm puzzled
Mikie98
Post by Mikie98 »
Hi Mike
Exact same issue as mine at the moment even car care clinic said they baffled.
I avoid driving the car as I don’t wanna cause more damage. I checked my oil to ensure it isn’t milky and there’s no white smoke from the exhaust so the head gasket might still be fine.
Does your coolant stay in the reservoir? I need to refill mine after I let it stand over night .
This is honestly mind boggling.
I have also created a post recently so if I hear anything I’ll give you a heads up.
Mikie98
Post by Mikie98 »
https://youtu.be/PYmRuc3ZVdw
I have found this link maybe you can give it a watch I’m gonna try it and see if it helps.
Mike2
Post by Mike2 »
Hi mikie98 I bought a new temperature sensor but I bought it at goldwagen
Maybe this car wants an original sensor don't
But please if you hear or get anything would really appreciate some positive feedback thnks again for your response sir much appreciated
If I get something will inform you buddy :hurray:
Mikie98
Post by Mikie98 »
Ohh no, and still the same issue? Have you possibly checked for leaks anywhere and made sure the oil is still fine in Dee the oil cap?
Possibly I mean it is VW after all haha.
No problem at all, sir. We in the same boat.
Thanks so much.
Mike2
Post by Mike2 »
Oil is f9 pitch black still
Mikie98
Post by Mikie98 »
Okay that’s a good sign then.
I had someone comment on my post earlier I am going to give a call in the morning and then I’ll let you know how it goes.
Mike2
Post by Mike2 »
Cool thanks buddy
EX-DOHCTOR
Registered for: 20 years 7 months
Membership No: 712
Post by EX-DOHCTOR »
Engine coolant temperature sensor.
Mike2
Post by Mike2 »
Hi ex-dohctor temp sensor has been replaced I bought it at goldwagen so now I' think maybe my car wants an original sensor or what because the sensor is new.
edriyadhed
Registered for: 3 years 3 months
Car Make: Audi TT
Car Model: 1.8T Quattro
Post by edriyadhed »
The gold wagen sensor kicks in at a higher temp vs the original. I replaced all the coolant temp sensors last year on my audi
Mikie98
Post by Mikie98 »
Hey Mike2 after you replaced your water pump did the leaking stop?
And was it leaking internally or was there coolant on the ground just wanted to find out as mine is doing the same and wanted to rule that option out as well.
Mike2
Post by Mike2 »
Mikie98 yes leak did stop
You couldn't see the because it only leaks when the car is driving so while the pump is working when I stop I can't see the leak but what I notice the bolt that bolts from the gearbox into the engine block was very rusted so that have me an indication there's water leaking there and the only explanation was the waterpump
I dd a pressure not even the pressure could indicate where the leak was so after I replaced the pump water leak was fixed
Mike2
Post by Mike2 »
edriyadhed wrote: Wed Feb 08, 2023 3:33 pm The gold wagen sensor kicks in at a higher temp vs the original. I replaced all the coolant temp sensors last year on my audi
Edriyadhed so are you saying I need to buy me the original sensor and take the goldwagen sensor out?
Mikie98
Post by Mikie98 »
Mike2
Ahhh I see thank you so much because my pressure test also couldn’t identify it. I was starting to worry but I will be replacing the water pump this month and then the sensor as well.
I will look at getting the oem sensor also then based on the above states with the sensor from Goldwagen.
We are getting somewhere, hooraaaayy.
Mike2
Post by Mike2 »
Mikie you right we heading in the right direction
n.gov3
Registered for: 8 years 2 months
Post by n.gov3 »
Faulty thermostat?
Mike2
Post by Mike2 »
Hi n.gov3
I replaced it with waterpump complete unit.
edriyadhed
Car Make: Audi TT
Mike2 wrote: Wed Feb 08, 2023 4:48 pm
If you having a temp reading problem then yes. That was done with mine. Had the goldwagen one, workshop was not happy with the temp reading and then replaced it with one from the agents.
Mike2
Post by Mike2 »
:iagree: Edriyadhed thanks you very much clarity much appreciated :iagree:
Mikie98
Post by Mikie98 »
Mike2 wrote: Wed Feb 08, 2023 8:32 pm Hi n.gov3
Did you get the thermo from Goldwagen also? Guessing I will need to do the same as well. Also gonna go to vw near me tomorrow and find out if they got the temp sensor
Mike2
Post by Mike2 »
Yeah I got it from goldwagen
Mikie98
Post by Mikie98 »
Mike2 wrote: Wed Feb 08, 2023 9:43 pm Yeah I got it from goldwagen
Thanks so much Mike
Just called VW And their sensor comes complete with the water pump they don’t sell it separate.So, trying to find out where to get an oem one separate.
