How to fix limp mode
Greetings i need help my polo tdi 1.6 loose power when i turn key off and on while in a motion the power came up again and i've changed many parts but there's no help still
- Car Make: VW, duh...
- Car Model: Stuff
Re: How to fix limp mode
Do a fault scan via VCDS or similar and then take it from there.
Changing parts without knowing what fault codes there are is a simple waste of money and time.
2012 Suzuki Hayabusa
2021 Aprilia RS660
2021 Aprilia RS660
I already scanned it many time and i go to Bosch service they scanned it and the told me to change timing ket and water pump i chaged them but the problem still the same... i change almost all sensor but still no help!
- mk2-phreak
- Registered for: 16 years
What are the fault codes?
