Engine limp mode
Allistairg1
Registered for: 5 years 1 month
Engine limp mode
Post by Allistairg1 »
Hi
I have a Golf4 1.9TDi with an AHF Engine.My odometer is currently standing on 542000Km.I am still driving 150km per day to and from work.
My problem is,sometimes when I want to accelerate fast,it will go but then suddenly it holds back,like if there is a lack of boost.I also used to drive up Sir Lowrys Pass in fifth gear at a speed of 120km/h.Now I can manage only 80km/h,and that is in fourth gear.Its like the engine has just loss its power.
I did replace some of my vacuum pipes but the one going to the turbo has not been replaced.
Can someone assist me in this matter?
Regards
Allistair
aristo92
Registered for: 10 years 10 months
Car Model: Golf MK7 GTI IS20H
Membership No: 3133
Re: Engine limp mode
Post by aristo92 »
Allistairg1 wrote:Hi
Regards
Allistair
Howsit bud, sounds like you may have a boost leak potentially. Do you get a engine light? Also where are you based.
Sent from my SM-N986B using Tapatalk
Regards, Armand.
Rides Thread: viewtopic.php?p=2577126#p2577126
Allistairg1
I am in Cape Town.I do get the engine light occasionally yes.What do you mean by boost leak?On a vacuun pipe?
Registered for: 18 years 7 months
Car Make: VW, duh...
Car Model: Stuff
Post by Jetta2 »
Boost leak can be anywhere on the turbo to intake.
Vacuum pipes, boost pipes, intercooler leaking or split on a seam, etc.
2012 Suzuki Hayabusa
2021 Aprilia RS660
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
What boost leak means in English is that the pressurised air from the turbo is not getting to the cylinders to make power.
Another question, does the car take long to start, especially in cold weather? Is there smoke present specifically white or grey smoke? If so at what times is it most visible?
aristo92
Membership No: 3133
Post by aristo92 »
Allistairg1 wrote:I am in Cape Town.I do get the engine light occasionally yes.What do you mean by boost leak?On a vacuun pipe?
Could be a boost leak on a boost pipe, could be a vacuum pipe leaking somewhere, could be a few things
Regards, Armand.
Rudi46
Car Make: Nike
Car Model: Walk and see more
Post by Rudi46 »
Also check stuck vnt on the turbo.
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
