2011 Amarok 2L TDI
MZA786
Registered for: 9 years 9 months
2011 Amarok 2L TDI
Post by MZA786 »
Hi Guys
i have been having a problem with my Amarok,
basically it was parked for a while ( probably 2 or 3 weeks )
now when i drive it and i get to a small incline and the vehicle is under load , the " GLOW PLUG LIGHT " flashes and vehicle goes into " LIMP MODE "
i have connected my OD2 plug to it when this happens but it does not pick up any error code,
i have plugged a normal scanner in it still no error
i first thought that is was cause it was due for a service but i have done the service and it still persists
the exhaust has a leak which i am going to try and sort out today
please advise if anyone has had this problem or could advise as to what i need to do
Gti3
Re: 2011 Amarok 2L TDI
Post by Gti3 »
Check all your boost pipes, you may have a leak. My Amarok had the same symptoms for a boost leak.
Sent from my SM-N986B using Tapatalk
2020 MK7.5 GTi DSG
EX:2013 MK7 TDi HIGHLINE DSG
EX:2010 MK6 GTI 6MT
EX:2006 Ibiza Cupra TDi
EX:1993 Golf 3 Gti
EX:1970 Beetle 1600 Twinport
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
I know some PD TDI's had that issue related to a faulty vacuum control box, not sure if a similar issue.
Also have heard of fuel related cuts when the fuel filter is dirty, the incline may be causing a blockage perhaps, maybe worth checking.
You can also browse the Volkswagen section of the 4x4community forum as well, you may find an answer there whilst you waiting.
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
MZA786
Post by MZA786 »
i have done the service on it, changed all filters, just waiting for a gap at the exhaust shop, they say the manifold is leaking, which could be the cause, and abit of a mission to sort out so they will need the bakkie for a few days, so im hopping for it to go in on monday to fix the leak, and im praying its just a faulty manifold gasket and not a crack in the manifold, will update as soon as i know, maybe it will help someone in the future
