1.9 asz injectors
- Car Model: Polo 9n 1.9tdi
1.9 asz injectors
hi guys does anyone know if the 1.9 tdi 96kz injectors can be repaired or serviced.
if not anyone got a set for sale.
- saxo
Re: 1.9 asz injectors
thanks i will join
i did they charging 5k each injector to service.
Thats about the going rate.
PD injectors are not the usual run of the mill items, they are somewhat specialised and not anyone can refurbish them.
You can also ask Diesel Works or a recommended place in Durban.
Be grateful you don't have a Polo 6R 1.6 TDI, those are much more expensive than PD injectors.
Why do you think the injectors are buggered?
- saxo
Some guys buy a 2nd hand engine from some engine seller, take out the injectors and sell the rest.
Will cost you less than 5k per injector.
buying the complete motor from mikes place just for the injectors. i found a couple guys selling between R1500 and 2k but no garantee.
the car missing and stalls while driving. when plugged in injector fault came up.
will the injectors from a 1.9 tdi transporter work?
