TDI flex downpipe repair/replace
VAG Fan
Post by VAG Fan »
My Mk4 TDI is starting to make a "fuzzy" exhaust sound from the front, and is also starting to smell of exhaust gas inside the car. I have a hunch it's the flex downpipe that's starting to go. (The one with the braided sleeve). Obviously I still need to confirm.
But supposing it is indeed the flex downpipe, any advice?
Can the flex section be bought separately and welded in?
Anyone around Pta. East (exhaust shop or otherwise) who you'd recommend to do such a repair properly, first time around?
missioner
Car Model: '87 MK1 Golf Citi
Re: TDI flex downpipe repair/replace
Post by missioner »
Yes it can be bought and installed without replacing the rest of the pipe.
Unfortunately I think the problem lies with the manifold gaskets, they are usually the reason for a "fizzing" sound. The reason for the noise is the gas passing the gaskets as the no longer close the gap between the manifold and the head.
The best way to test is to block the exhaust and go have a listen at the front. If it's difficult to pinpoint the leak, use a pipe like a stethoscope. Hold one end to your ear and then use the other to see where it's leaking by holding it near the gaskets and joins.
VAG Fan
Post by VAG Fan »
Thanks for the response.
Good news that the flex section can be replaced if needs be.
Indeed I was wondering about gaskets. I must say, though, that there is no rhythm to the fuzzy or fizzing sound. It's very light, and very even, and only audible at idle. Under load and higher revs, there is no audible abnormal noise. The manifold leaks that I've heard up to now, were all rather well defined and pulsing, and grew louder with load. This is why I'm hoping it's further back.
Also, the Garrett OEM-spec turbo (I think, a GT1749VA) is manufactured as one casting that includes the manifold. This was replaced just over 2 years (about 30k km) ago - I did this together with Panic at his place. So I would hope that the gasket isn't failing already.
Either way, good idea to pinpoint the fizz with a pipe stethoscope. I'll try that.
