2012 T5 Caravelle Slow On Revs Uptake
FerdinandBabst
Registered for: 4 years 4 months
Post by FerdinandBabst »
Hi. I have a 2012 T5 and I am noticing that when I need to accelerate i.e. on green traffic light, the car takes long to build up revs. Even if I put my foot down. I have changed all filters etc checked and I have no issues with Turbos or anything. Apart from the slow uptake the car runs fine.
Neuk
Treasurer
Treasurer
Registered for: 19 years 7 months
Membership No: 806
Re: 2012 T5 Caravelle Slow On Revs Uptake
Post by Neuk »
What engine does the car have?
FerdinandBabst
Hi
Its a 2.0 TDI
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Have you had the car scanned for fault codes? Does the car 'feel' fine after a certain rpm?
FerdinandBabst
I think ill have it checked out at VW. I just thought its an easy fix.
VAG Fan
Post by VAG Fan »
You say you changed all filters, so if you changed the air filter, did you remove the plug of the air mass flow sensor and perhaps forgot to plug it back in?
This happened to me, and my 1.9 TDI had exactly those symptoms. Ran totally sluggish, but otherwise fine.
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
VAG Fan wrote: Thu Mar 18, 2021 9:30 am You say you changed all filters, so if you changed the air filter, did you remove the plug of the air mass flow sensor and perhaps forgot to plug it back in?
That or what I have seen with other VNT turbo TDI engines is vanes that get stuck, either open or closed so you either have no boost initially or not boost at higher rpm.
