SOLVED: Polo Sportline no crank no start issue
Abominable_Snowman
Registered for: 8 years 3 months
Car Model: Polo 1.9 TDI Sportline
Post by Abominable_Snowman »
Hope you may be able to shed some light on this, but having trouble starting the polo since last week.
Had intermittent starting issues early last week, few taps on the starter and fired right up. Few days later, while driving home, dash lights flickered, ABS and steering wheel lights came on, Power steering went dead, boost started fluctuating. About 2km’s further, the car just stalled while in 3rd doing about 50km per hour. Just rolled to a stop. Wouldn’t crank or anything.
A kind stranger stopped and helped me get it started again, drove about a km before the exact same thing happened. This time, no luck at all, wouldn’t start, no dash lights, battery was dead, wouldn’t even kick start.
Got a tow home, did some digging, pulled the starter out, replaced it last night with a working one, charged the battery… Still no crank, but the dash lights are on.
The battery tests at 12.8V while disconnected. New ground cable from battery post to body has been installed.
Could someone please point me in the right direction so I can hopefully get this car running again and I can stop using public transport lol
Just a note: the previous owner had the battery moved to the boot when he had it, it’s since been moved back to the front of the car.
Vehicle info: 2005 VW Polo 1.9 TDI Sportline.
Any help would be greatly appreciated guys
Thanks in advance
Last edited by Abominable_Snowman on Sun Feb 28, 2021 2:58 pm, edited 1 time in total.
Jeremiah | Durban
21' VW Polo Sedan 1.6 Comfortline (Current)
05' VW Polo 1.9 TDI Sportline (Sold)
'06 Seat Ibiza 1.9 TDI FR (Sold)
'12 VW Jetta VI 1.2 TSI (Sold)
'15 Ford Figo 1.4 (Sold)
'01 Fiat Palio 1.2 (Sold)
'95 VW Citi Golf 1.3 (Sold)
'91 BMW 318i (Sold)
'89 Opel Kadett SR (Sold)
Howie-WP
Membership No: 2033
Re: Polo Sportline no crank no start issue
Post by Howie-WP »
Crank position sensor?
Abominable_Snowman
Howie-WP wrote: Wed Feb 17, 2021 1:07 pm Crank position sensor?
Thanks Howie, I'll have a look at it.
Jeremiah | Durban
'91 BMW 318i (Sold)
superflyza
Registered for: 4 years 4 months
Post by superflyza »
i had the same issue, i just got my 2016 tsi 1.2 on friday, saturday morning no start, starter not even swining, ECR light not, well it ended up to be the Key, they reprogrammed a new key which worked for 1 day, got the spare key and the car started no issues
superflyza
High Fuel consumtion
hi all,
I just a got a 2016 polo tsi 1.2, i been trying to drive economy mode but for some reason i cant get this car below 7.5 per 100km urban, i change gears before 2000rmp ect..
From what i have seen it should be much lighter than that, any ideas would be appreciated
J0NN0
Registered for: 13 years 5 months
Car Make: No Name
Car Model: Tekkies
Membership No: 1725
Post by J0NN0 »
Hi @superflyza I suggest an introduction to the forum first - Introduce Yourself.
Once you've done that, Start your own thread with the issue you have at hand.
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
Howie-WP
Membership No: 2033
Post by Howie-WP »
Abominable_Snowman wrote: Wed Feb 17, 2021 2:38 pm
First have the car scanned by someone with a vagcom/vcds or obdii scanner, should give you a better idea. Rather than haphazardly buying replacement parts....
Ashveer03
Post by Ashveer03 »
A faulty crank sensor wouldn't cause a no crank.
Check ur battery voltage when trying to crank. I seen full powered batteries fail to even click a solenoid, forget cranking.
Since the battery has been relocated, how is the starter wire hooked up now?
Starter b+ should be going straight to the positive terminal, unfused.
If all turns out good, check for power on the solenoid wire when trying to crank.
If u have a known good battery, swap it out and check.
Callum229
Post by Callum229 »
I agree with Ashveer03.
Crank sensor won't prevent it from cranking over or attempting to start.
You have to start with the diagnostics, get the car scanned.
Another common issue is it could be the ignition starter thingy (not sure what the name is).
On my car I had no ACC function because the ignition was faulty, Goldwagen sells the part and it also came up with a code 00849 - S-Contact at Ignition/Starter Switch (D): Unknown Switch Condition. Since the ACC function is in the middle of the key cycle, the car didn't detect it hence there a code as I have to pass ACC then ignition on and then engage starter. As the starter is in the end of the ignition cycle, it might not throw a code.
The contacts in the ignition starter switch tends to go bad or break off. This can also cause no power to dash and/or no cranking issues.
But first, try and get it scanned, that will narrow the issues down significantly.
Abominable_Snowman
Hi guys, sorry it's taken me so long to respond, been swamped with work. Anyways... Onto the car, thanks for the suggestions guys, I've had the car scanned, no errors pointing to the ignition switch.
Instead, a range of errors saying "implausible signal". After asking some VW macs, the common response is I most likely have a bad ground/ battery issue. The battery was also checked and it was indeed toast. Got that replaced yesterday, turned the key and now I simply get a single click.
This is progress... Much better than the awkward silence lol. I now suspect the starter/ grounds are at fault. I had replaced the starter with another second hand working one last week, but I'll check it again, maybe it's also decided to go wonky on me. I'll check the starter and all the ground points. It started to rain last night so I had to call it quits.
I can only visibly see 3 ground points (battery to body, one just next to the ECU and one other one just behind the fuel filter), can't seem to see where the engine/gearbox ground strap is located, does anyone know where its placed? Also, are there any other earth points I should check?
Thanks for all the help so far guys, you've helped me a lot!
let me know if you'd like me to post the scan here.
Jeremiah | Durban
'91 BMW 318i (Sold)
Abominable_Snowman
superflyza wrote: Wed Feb 17, 2021 2:45 pm i had the same issue, i just got my 2016 tsi 1.2 on friday, saturday morning no start, starter not even swining, ECR light not, well it ended up to be the Key, they reprogrammed a new key which worked for 1 day, got the spare key and the car started no issues
Thanks Superfly, I'm glad you managed to track the issue down. I doubt my key is the issue, however, this car didn't come with a spare so I can't check it. But I will keep it in mind in case the starter and ground idea doesn't pan out.
Jeremiah | Durban
'91 BMW 318i (Sold)
Abominable_Snowman
Re: SOLVED: Polo Sportline no crank no start issue
So, just an update, she's back on the road. I tracked all the ground points down, cleaned them up nicely and along with the new battery, the car started without any hesitation.
thanks for all your help guys!
Jeremiah | Durban
'91 BMW 318i (Sold)
