Golf 5 1.9 TDI springs
MohamedU
Post by MohamedU »
Hi guys, wrt the springs on a golf 5 1.9 TDI, what lowering springs have you guys fitted?
J0NN0
Registered for: 13 years 5 months
Car Make: No Name
Car Model: Tekkies
Membership No: 1725
Re: Golf 5 1.9 TDI springs
Post by J0NN0 »
howzit bud, Golf 5 platform the same as the Leon FR and I had the VWR springs with the Bilstein shocks on my FR and all I can say is wow! absolutely amazing.
If you going low for some stance I would recommend going the coil over route as once you start lowering the bug bites and at least you can adjust it lower where the springs will be a fixed height. FK is not a bad brand and not too pricey.
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
MohamedU
Post by MohamedU »
J0NN0 wrote: Wed Jan 13, 2021 1:50 pm howzit bud, Golf 5 platform the same as the Leon FR and I had the VWR springs with the Bilstein shocks on my FR and all I can say is wow! absolutely amazing.
I have checked out coilovers but the description didn't mention it can be used on the tdi. So that's where the confusion comes in.
Regarding the shocks, just replaced the standard ones as they were shot, so have to go the spring route now. Would like a mild drop only.
I bought this car not knowing the springs were cut, took it for alignment, and sh*t, they were bad. Decided not to drive it until I replace the springs.
J0NN0
Car Make: No Name
Car Model: Tekkies
Membership No: 1725
Post by J0NN0 »
I'm no expert, but I'm 90% sure you can use the coil overs on the TDI.
In terms of replacing your shocks, I recommend the VWR but not sure who supplies them. Most common ones I hear of guys using is H&R springs.
What drop are you looking for? 20? 30? 40?
Jonno
2007 SEAT LEON FR
MohamedU
Post by MohamedU »
J0NN0 wrote: Wed Jan 13, 2021 9:01 pm I'm no expert, but I'm 90% sure you can use the coil overs on the TDI.
Looking for like a 20 drop. Was even considering GTI springs for the TDi then on some forum it mentioned that due to the weight of the TDI engine, the front will be much lower.
J0NN0
Car Make: No Name
Car Model: Tekkies
Membership No: 1725
Post by J0NN0 »
MohamedU wrote: Thu Jan 14, 2021 8:30 am
Yes I have heard the same, the springs are not the same for G5 divertives but the coilovers will be the same. (I'm pretty sure)
If only 20mm drop look at the VWR :thumbup:
Jonno
2007 SEAT LEON FR
DieterMK5
Registered for: 11 years 4 months
Car Model: Jetta MK5 1.9 TDi
Membership No: 3015
Post by DieterMK5 »
You will need to find 50mm hub coilovers as the tdi has 50mm instead of 55mm on the petrol models. Just make sure it’s correct. I made the mistake of buying coilovers only to find they were 55mm hubs instead of 50mm
DJ7
Car Model: MK5 2.0 TDI DSG
Membership No: 3238
Post by DJ7 »
I thought that the 2.0 TDI Sportline and the GTI shared suspension components, I could have been mistaken then.
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
