Z3 cooling system fail
MMS Auto is a small privately owned and operated Motor vehicle workshop that specializes in Quality services and exceptional maintenance at affordable prices.
Rascal69
Registered for: 17 years 2 months
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
Customer calls me up and says he got a radiator leak on a car he just purchased. We arrange and he brings it in . This is what I have to work with. 122000kms on the clock.
Removed the radiator ... Image shocked.
Radiator broke so the previous hack mechanic qbond it shut. Then tap a new valve and seal with with bathroom silicone, pratley steel and qbond. And expected it to hold pressure under operating temps.
I opted for a new radiator, took two weeks but it arrived and everything became clear.
Will post more as we progress.
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Greenz
Car Model: Focus ST225
Re: Z3 cooling system fail
Post by Greenz »
Dafuq!?!?!?
2010 ST225 - 246kw 498nm
2008 Tenaciti 1.4i
Registered for: 14 years 3 months
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
Tjeeeeer
That Old Radiator has seen better days, pure abuse of such a gem of a car of low kilos.
DJ7
Car Model: MK5 2.0 TDI DSG
Membership No: 3238
Post by DJ7 »
How some people can do things like that is beyond me.
Sent from my SM-A305F using Tapatalk
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
Yeah guys, there’s people out there hacking away at customers cars.
I’ve got a lot of work planned for the z3:
1. Full engine service
2. Auto Gearbox service
3. Diff oil change
4. Full cooling system refresh: radiator, thermostat, updated aluminum thermostat housing, new waterpump, new water bottle and cap as well.
5. New Ac belt, tensioner, pulley.
6. New V belt , tensioner and pulley.
7. New Tappet cover gasket
8. Front seals on cyl head
There’s a lot of sludge build up in here so I have to run engine flush with new wolf 5w40 oil , then drain out as much of the sludge before Filling up with the LM molygen oil and Ceratec additive.
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
Z3 is out the workshop so it’s time to update :
Started collecting parts :
Began with a service
Then we started with the cooling system issues. Drained the radiator and the engine block of all the water they had filled when doing the shitty repairs .
And then started getting the radiator out
Had to cut this pipe as they stuck it on .
Called up Bmw and placed an order for a new radiator and that pipe which We cut.
Gearbox oil cooler mounted to the old radiator, will be swapped over to the new unit
These two seals had an oil sweat, while we were there we replaced them too
Then both the belts, tensioners and pulleys needed to be replaced, so those where ordered too.
We then fitted the radiator and the rest of the new components in the cooling system.
We noticed a lot of sludge build up when replacing the tappet cover so we decided to do an engine flush with cheap oil before filling up the more expensive liqui moly engine oil with the Ceratec additive .
Then we drained the old Geabox Fluid out .
Dropped the gearbox oil pan and the oil filter
Cleaned and prepped for the gasket.
New gasket
Installed the new filter and gasket and bolted up the oil pan then torqued to spec.
Filled up gearbox oil the old school way lol
Checked coolant and top up
Add Ceratec additive
Fill up with oil and a new oil filter
Also drained and filled new oil in the differential
New belts and tensioner
Vehicle completed and owner collected. He was Very happy guy after this since he now had confidence in his vehicle and wasn’t afraid to drive back to pta.
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
Belix
Car Model: Passat B8
Post by Belix »
Quite a job there, thanks for the walk-through and pictures.
Ancient lg term project: Golf GT
