Getting ready for VKC 2020
MMS Auto is a small privately owned and operated Motor vehicle workshop that specializes in Quality services and exceptional maintenance at affordable prices.
Rascal69
Registered for: 16 years 1 month
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
It’s this time of year again where I do my annual Service . This time I figured I’ll also address some other things so the car is in good shape and ready for the track at the end of the month.
Things we were going to do:
Engine Major service
Cooling system flush and bleed
Power steering flush and bleed
Diff oil flush and refil with bmw oil
My list of parts where as follows:
I got the majority of parts from Jaco @ Delarey and then the oil filter , diff oil (M LSD Specific) and wiper blades and coolant from bmw . The diff oil is very expensive R550 for 500ml. You need 3 bottles . I also changed the Liqui Moly Hydraulic fluid for Castrol ATF DEX3 as that is the correct power steering fluid for this vehicle.
Then I went for a small drive got everything warm, came back, put the car on the lift and started out by draining the engine oil.
Left that to properly drain for about 2 hrs then
Replaced the crush washer and refitted the sump plug and torqued it.
Next I went over to the rear and drained the diff oil out : didn’t get pic of the refil with the new fancy bmw oil.
Then I went back to the front and opened the power steering line to drain the fluid. Didn’t get pics of the refil process and bleeding .
Also got new O-rings for the power steering line which I had opened to drain from .
Next I replaced the air filter.
Removed the old oil filter . It said 122450kms was when it was replaced .
We on 125500kms now so a total of 3050kms have been covered since the last oil service a year ago. New filter marked with mileage. Image
And then installed
Swapped over the O-rings and installed the OFH cap and bolt then torqued down .
Torque specs
Old filter didn’t look to bad either , didn’t bother to cut it up and check for any metallic particles so I threw it in the bin.
Called it a day and left
The next day I started out by draining the cooling system. First the radiator and reservoir then the engine block.
After it had all drained out , we closed the drains and filled up with 60/40 mix of distilled water and coolant . Total capacity filled was about 10.5 liters .
Next up I filled the Ceratec in and then topped up with the LM 10w60 oil (not sure why I didn’t get a pic filling the oil)
Then I removed the coils and plugs and fitted the new set, torqued to spec , think it was 23nm on the box
New plugs and coil packs refitted
I also stripped the front brakes , cleaned them and refitted everything.
Here is the caliper bracket. I cleaned off the contact surface where the pad runs on. U can see the before and after.
Both done
Cleaned out the hub and brushed it with anti seize paste.
Cleaned out all the slider pins and screws .
Sprayed the pads with anti squeal spray
Took the discs outside and blew it clean with compressed air. Made sure to get in all the holes and vents to get as much brake dust out of it as possible then I Refitted the discs
Sprayed the contact surfaces of the bracket with anti squeal spray and then fitted it. The slider pins were coated in silicone paste and then installed.
Lastly the pads caliper and clip were all fitted and we were done with the fronts and I called it a day.
The next day I pulled of the rims and tires to fit my square setup with the 265’s all round.
Redid the tyre lettering in red .
And fitted them to the car
Replaced my wiper blades with a new OEM set.
And got the car down on the ground.
I did start warm up, check oil level then allow to cool down completely and check coolant level which went down a little and needed a top up , we connected the laptop and ran diagnostics, had some old errors which were saved on the ecu that needed clearing . Once that was completed , I reset the adaptations and took the car on a test drive . Came back and checked oil, level was perfect. Next morning I checked coolant again and it was still perfect so I’m happy with this. I will daily the car to make sure everything is perfect before taking it in for alignment and then hitting the track Image
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
DieterMK5
Car Model: Jetta MK5 1.9 TDi
Membership No: 3015
Re: Getting ready for VKC 2020
Post by DieterMK5 »
Love the detailed log bud gives others a good “how to” in prep for a track day, and regular maintenance
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
DieterMK5 wrote:Love the detailed log budImage gives others a good “how to” in prep for a track day, and regular maintenance
Much appreciated Thanks buddy Image
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
NHB_R
Registered for: 11 years 11 months
Post by NHB_R »
Nice write up! Even nicer car!!
