Polo 1.9tdi
Kivashan
Polo 1.9tdi
Post by Kivashan » Fri Oct 11, 2019 12:28 am
Hi guys....
Please assist I have a polo 1.9tdi. I just did the complete motor.
Car has big injectors and turbo
Am currently having the issue whereby I cannot start the car it keeps swinging but doesn't take. Only if I spray quick start for a while it will take and once I switch off it won't start again. I have changed the cam sensor logged the car on vcds the injectors seem to be fine the timing is at 2.88 and goes to 3.2. I have also tried another tandem pump, also checked the fuel lines to the tandem pump and there is fuel coming through however issue is still there.
Please can someone assist if they had this issue or knows what could be wrong.
Ashveer03
Re: Polo 1.9tdi
Post by Ashveer03 » Fri Oct 11, 2019 12:40 am
Does the engine only run on quickstart or does it run on its own?
Verify fuel lines.
Blue is the return line, fits on the bottom of the tandem pump.
And white the feed.
Thekogm
Car Make: VW & VW
Car Model: 95 Polo 1.4i, 03 Transporter
Re: Polo 1.9tdi
Post by Thekogm » Fri Oct 11, 2019 1:24 pm
Ashveer03 wrote:Does the engine only run on quickstart or does it run on its own?
Verify fuel lines.
And white the feed.
If the car is fueling properly, check both crank AND cam sensors. I had a similar issue and replacing those got the car starting.
Good luck...
Sent from my MAR-LX1M using Tapatalk
:type: or on the phone...
Kivashan
Re: Polo 1.9tdi
Post by Kivashan » Sun Oct 13, 2019 2:45 pm
Verify fuel lines.
And white the feed.
Have to use quick start to get the car started there after its okay once I switch off doesn't want to start again unless I spray quick start
Kivashan
Re: Polo 1.9tdi
Post by Kivashan » Sun Oct 13, 2019 2:47 pm
Verify fuel lines.
And white the feed.
Good luck...
I've tried only a new cam sensor so far due to no faults picking up on vcds
