g'day
A lot of the enjoyment of the Dynaudio system in my car is destroyed by vibration of the speaker housing when playing certain songs - something I never had with the stock G6 system.
I'm not one for blasting my ears, so this happens even at the 1/2 volume levels and below I play at.
Different songs affect different doors.
The car is under warranty but I don't imagine I'm going to get much joy on this from VW techs.
I was thinking some dynamat stuck on the inside of the door panels might fix the issue, but have zero experience with dynamat. Would it help?
Vibration in speaker housings
- Belix
- Car Model: Passat B8
Ancient lg term project: Golf GT
- Car Make: VW, duh...
- Car Model: Stuff
Re: Vibration in speaker housings
Could be caused by certain frequencies making either the speaker housings vibrate against the doors or the speakers themselves against the housings.
A buddy had a similar issue in his Passat.
We removed all speakers and speaker housings and put that thin sponge stuff with adhesive on one side (got it at Builders) around all the edges where the housings go against the doors and where the speakers sit on the housings.
Problem was solved.
Dynamat works beautifully. I did the whole Caddy with it and it cuts down road noise massively and improved the SQ by a huge amount.
Problem was solved.
2012 Suzuki Hayabusa
2021 Aprilia RS660
2021 Aprilia RS660
- Belix
Thanks R!
Annoyingly, getting time to do this lately is an issue. Is this something a decent audio installer would do?
- Car Model: Stuff
Cool stuff.
A decent installer can do it, yes. But they might just charge you an arm or a leg. Or both including a kidney.
2021 Aprilia RS660
2021 Aprilia RS660
- Car Make: Ford
- Car Model: Focus ST225
You get what you pay for but a really worth while expense in the end.Makes a world of difference.
2010 ST225 - 246kw 498nm
2008 Tenaciti 1.4i
2008 Tenaciti 1.4i
