2l 8v not driving after i serviced it.
MJ 2l 8v
Post by MJ 2l 8v » Fri Jul 12, 2019 12:14 pm
Good Day People,
I'm new to the mk1 golf family.
I recently bought me a 2l 8v with a dictator management. (my first car)
I serviced my car Saturday past, and now it doesn't want to drive.
all i did was change the spark plugs, petrol filter, and oil. (oil filter was a struggle to take off so i left it on because my old spark plug was not in a bad condition)
I had a friend of mine look at the car, but couldn't determine why the car is unable to drive.
The car starts up and idle but then dies after a few minutes.
I'm thinking it could be one of two things or both. My 3 pin coil or my dictator management.
can anyone please assist?
I wouldn't want to take it to be tuned and than that's not the problem.
Regards
MJ 2l 8v.
THANAS
Car Model: G7 GTi
Membership No: 2035
Re: 2l 8v not driving after i serviced it.
Post by THANAS » Fri Jul 12, 2019 12:28 pm
Hmmm...
_Image_Image_Image
Car Make: Fiat, Toyota
Car Model: Uno, Auris
Post by Unobeat » Fri Jul 12, 2019 5:30 pm
Hmmm...
Double Mmmhhh
You need to make a plan bro, remove and change out that Oil filter.
You cannot put in new oil into a motor with old oil filter.
Sent from my SM-A500F using Tapatalk
Warm caddy
Post by Warm caddy » Mon Jul 15, 2019 7:35 pm
Get yourself the oil filter wrench type, not the belt, get the 3 jaws one, it will take it off
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn » Tue Jul 16, 2019 8:50 pm
what fuel filter are you using?? As in brand?
2000 Golf 1 Chico- CRANKCASE [Std bottom end, head gas flowed,ported & chopped by Fastcar, 288 Estas Billet, 4-2-1 43mm Brospeed Branch, 50mm-57mm-63mm Exhaust] + THE PART (2B1 speacials) -Final power @ Autotrix 111wkw & 210wnm :drool:
2011 Jetta 5 1.6 TDI DSG - CRANKCASE Tow Services [CPI Stage 1 with DPF Delete & 57mm Straight pipe]
MJ 2l 8v
Post by MJ 2l 8v » Wed Jul 17, 2019 10:51 am
Problem sorted.
wires from my coil to my distributor was laying against my fan, so each time I my drove my car the fan was eating away wires.
Post by Unobeat » Fri Jul 19, 2019 12:55 pm
Problem sorted.
Glad you sorted. :cool:
