high fuel consumption and burning rich
macascal
Registered for: 6 years
Post by macascal »
hi there its max here
well I have a jetta 4 1.6 sr akl motor ive been having issues with it burning rich ...when I rev her up certain times I hear a pop sound from the front of the car like from the engine bay...its also very heavy on fuel ....I have done a full service, I have changed temperature sensor, I have changed oxygen sensor, I have changed plug leads and I checked vacuum leaks and all that is in check I have enough power on the freeway but sometimes taking of is a problem where it will hesitate and then move. Does anyone know what I should check next or what the problem may be....?
thanks
Re: high fuel consumption and burning rich
really hard without doing some sort of diagnostics. can be so many things.
compression
airflow meter
fuel pressure
cam timing
cam timing pickup
leaking / bad injectors
etc etc etc.
Tyrrell
Registered for: 5 years 2 months
Post by Tyrrell »
Did you find your problem cause I'm having the same problem
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
Book it in for a diagnostic at a mechanic.
