FWD to RWD
makzin
Car Model: MK1 Citi Sport 1.4i
FWD to RWD
Post by makzin » Thu Jun 13, 2019 8:46 am
Sup People.
Was wondering how much or how hectic will it be to convert a front ween drive car to a rear wheel drive. I saw a WV Mk2 that was rear will drive. So it is possible but just want to find out what to look out for on such a project
the open road with curves makes driving an absolute pleasure :driving: :popcorn: :troll:
Re: FWD to RWD
Post by panic-mechanic » Thu Jun 13, 2019 8:57 am
A lot.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
amstel18
Car Model: Polo TSI
Re: FWD to RWD
Post by amstel18 » Thu Jun 13, 2019 11:38 am
If you need to ask, then you can't do it...
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
OettingerTDi
Car Make: Audi / VW
Car Model: S4 / Citi / Caddy / Polo
Re: FWD to RWD
Post by OettingerTDi » Thu Jun 13, 2019 12:14 pm
I would seriously suggest that you perhaps hop onto the internet and google this or check out Youtube, I'm sure that many others worldwide have tried and documented this.
Anything is possible in theory, but unless you are a very skilled panelbeater with lots of time, CAD/CAM skills and with access to some jigs, cutting and welding tools, it's not something for the feint hearted.
Anton van Graan
2007 Caddy Life TDi
2004 Polo 1.6 Comfortline
2003 Audi S4
1997 Chico 1.3
2000 Jetta 4 TDi
1999 Uno Turbo
1993 Uno Turbo
1988 Ford Laser 1600i Sport
makzin
Re: FWD to RWD
Post by makzin » Thu Jun 13, 2019 1:13 pm
amstel18 wrote:If you need to ask, then you can't do it...
True Image
makzin
Re: FWD to RWD
Post by makzin » Thu Jun 13, 2019 1:16 pm
OettingerTDi wrote:I would seriously suggest that you perhaps hop onto the internet and google this or check out Youtube, I'm sure that many others worldwide have tried and documented this.
I did some research. I have no panel beating experience but have a project I've been meaning g to start. Just need to get direction. This RWD was an idea but after a few hours of Google it will very expensive
OettingerTDi
Car Make: Audi / VW
Re: FWD to RWD
Post by OettingerTDi » Thu Jun 13, 2019 1:40 pm
It will essentially be a full strip down to a bare bodyshell and cutting it to pieces to fit a modified floorpan to accommodate the now longitudinal engine, modified firewall, transmission tunnel, propshaft and diff to start with. Then adding the various mounting points for the suspension and drivetrain and strengthening of the chassis, where necessary. You will essentially be building a car from scratch.
I have seen how Volkswagen Motorsport builds an S2000 Volkswagen Polo 4-wheel drive rallycar, the tools required as well as the CAD designs involved. If you have no relevant experience and presumably not the tools referred to earlier, you are in the deep end of a bottomless pool of wallet emptying effort, as confirmed by Google.
Anton van Graan
2007 Caddy Life TDi
2003 Audi S4
1997 Chico 1.3
2000 Jetta 4 TDi
1999 Uno Turbo
1993 Uno Turbo
VAG Fan
Re: FWD to RWD
Post by VAG Fan » Thu Jun 13, 2019 2:10 pm
Just for argument's sake, what about starting with a syncro drivetrain? A Mk2 Syncro (for example) doesn't have a longitudinal engine. Is the body all that different from a FWD Mk2?
OettingerTDi
Car Make: Audi / VW
Re: FWD to RWD
Post by OettingerTDi » Thu Jun 13, 2019 2:41 pm
Everything up to the firewall will probably be OK, perhaps just having to accommodate the Syncro gearbox and transfer case, but from there on backwards is a redesign of the floorpan to accommodate the propshaft, exhaust, rear suspension and so on.
Also bear in mind that trying to find a Syncro set up to fit a MK2 body will be impossible in SA, as we never got them here, so you will need to import a used set-up or try to find one of the two ex-factory Golf Syncro's that were rallied here in the late 80's, early 90's. You can probably try to find a set-up as used in the Volkswagen T3 Microbus Syncro, but the dimensions will be totally different and would require heavy modification to fit.
Anton van Graan
2007 Caddy Life TDi
2003 Audi S4
1997 Chico 1.3
2000 Jetta 4 TDi
1999 Uno Turbo
1993 Uno Turbo
makzin
Re: FWD to RWD
Post by makzin » Thu Jun 13, 2019 2:51 pm
Sh%T that's pricey...
OettingerTDi
Car Make: Audi / VW
Re: FWD to RWD
Post by OettingerTDi » Thu Jun 13, 2019 3:19 pm
Although it sounds like a lekker project, there are so many things to consider, of which the price of the components is probably the cheapest. It's the cost of planning, tools, labour and trail and error that will determine the project's success.
Assuming you get the whole project done, the next big hurdle would be to register the whole lot if you intend using it on our roads. Different weight specifications and most probably a different engine. Getting insurance should be fun too.
To quote my Dad - If the short cut was really that short, the long route would have gone that way.
Anton van Graan
2007 Caddy Life TDi
2003 Audi S4
1997 Chico 1.3
2000 Jetta 4 TDi
1999 Uno Turbo
1993 Uno Turbo
makzin
Re: FWD to RWD
Post by makzin » Thu Jun 13, 2019 3:23 pm
OettingerTDi wrote:Although it sounds like a lekker project, there are so many things to consider, of which the price of the components is probably the cheapest. It's the cost of planning, tools, labour and trail and error that will determine the project's success.
So a engine swop is the safer bet.
Car Make: VW, VW, Aprilia
Car Model: VR6, Caddy, RSV4
Re: FWD to RWD
Post by Jetta2 » Thu Jun 13, 2019 3:29 pm
A client of mine wanted to build a Mk2 Rallye clone.
He found the complete running gear (front suspension, gearbox, propshaft, rear diff, rear suspension, etc) somewhere on Ebay, but the cost to get the stuff to SA would have been over 6oK. And that excludes the price of the parts, that was just the shipping costs.
He did calculations and what not and IIRC, the rough figure was around 200K for JUST the parts needed before the build process would even begin...
Needless to say he canned the idea and did an ABF turbo setup.
2017 Caddy Maxi 2.0 TDI
OettingerTDi
Car Make: Audi / VW
Re: FWD to RWD
Post by OettingerTDi » Thu Jun 13, 2019 3:30 pm
Assuming you want to beef up the performance in your 1.4i per your avatar, yebo
Anton van Graan
2007 Caddy Life TDi
2003 Audi S4
1997 Chico 1.3
2000 Jetta 4 TDi
1999 Uno Turbo
1993 Uno Turbo
makzin
Re: FWD to RWD
Post by makzin » Thu Jun 13, 2019 3:33 pm
I'm not needing that one up. Recently bought a Mk2 GTI with a dead engine and gearbox.
It needs: engine, gearbox, seats and dash.
OettingerTDi
Car Make: Audi / VW
Re: FWD to RWD
Post by OettingerTDi » Thu Jun 13, 2019 4:07 pm
2.0 litre 8valve or ABF 16valve plus gearbox and some other toys to make it work would be a ideal combination. Plus no modifications to body or chassis required.
Anton van Graan
2007 Caddy Life TDi
2003 Audi S4
1997 Chico 1.3
2000 Jetta 4 TDi
1999 Uno Turbo
1993 Uno Turbo
ICE King
Re: FWD to RWD
Post by ICE King » Thu Jun 13, 2019 4:32 pm
Trying to do a unique build with a Mk2 is going to be tough and very expensive if you're not able to DIY,
every possible combination of mods/drive-train/engine was done before ,anything is possible with loads of cash.
Rides:
