ABS ESC error
Abominable_Snowman
Car Model: Jetta VI 1.2 TSI
ABS ESC error
Post by Abominable_Snowman » Sat May 18, 2019 10:31 am
Okay so, last Saturday I had the car idling to warm up as usual before I could hit the road. As I start moving, the ABS and ESC lights pop up. These lights have not gone away.
So, tried clearing the codes with an OBD scanner and app -(that didn't work).
Asked a mate for a favor and hooked the car up to VCDS. Picked up an ABS error (01101000). Cleared the codes, switched the ignition on and off and ran a new scan and got this error: 01130 - ABS Operation: Implausible Signal
That keeps coming up. After scanning during a test drive, my mate says that the front right has a voltage that seems to have a large variance compared to the other wheels.
I've checked the sensor, it was faulty, replaced it and the error is still there. I've also checked the wiring, that seems to be okay.
Some research suggests it could be a wheel bearing or the abs module.
Thoughts on this?
Jeremiah Naicker | Durban
'06 Seat Ibiza 1.9 TDI FR (Current)
'12 VW Jetta VI 1.2 TSI (Current)
'15 Ford Figo 1.4 (Sold)
'01 Fiat Palio 1.2 (Sold)
'95 VW Citi Golf 1.3 (Sold)
'91 BMW 318i (Sold)
'89 Opel Kadett SR (Sold)
Absolute Detailing - Mobile Automotive Detailing
Abdullah
Re: ABS ESC error
Post by Abdullah » Sat May 18, 2019 11:48 am
This happened to me with my audi, after replacing my wheel bearings they damaged the sensor, if i remember correctly if was the wheel speed sensor but it would happen now and then. Never got around to sorting it out
Abominable_Snowman
Re: ABS ESC error
Post by Abominable_Snowman » Sat May 18, 2019 5:03 pm
@Abdullah shucks man, sorry dude. Best you get it sorted though, a friend of mine suggested that if it's left unchecked it could lead to other problems.
I'm going to get another wheel bearing tomorrow and Jack the car up to fit it. Hopefully it sorts everything out
'91 BMW 318i (Sold)
Pik Sooter
Car Make: Toyota
Car Model: MK6 Hilux 3.0 DI l MK2 Audi TT
Membership No: 1893
Re: ABS ESC error
Post by Pik Sooter » Sat May 18, 2019 6:42 pm
ABS and ESC light is wheel bearing. Had the exact same issue on my Jetta. Both lights came on, lost all breaking control, scanned the car, ABS sensor implausible signal. Bought 2 new front ABS sensors, took car to a trusted mackie to fit, phones me about an hour later, tells me the front right wheel bearing is shot. Decided to replace both right and left hubs/bearings and also install new ABS sensors, sorted the problem right out.
Abominable_Snowman
Re: ABS ESC error
Post by Abominable_Snowman » Sun May 19, 2019 7:55 pm
@Pik thanks man, you've confirmed my suspicions. I just replaced the sensor and the error is still present. Thank you for your feedback, I really appreciate it. I will be replacing the bearings this week and I'll post an update on the result
'91 BMW 318i (Sold)
Abominable_Snowman
Re: ABS ESC error
Post by Abominable_Snowman » Sun May 26, 2019 8:55 am
Update: So I have replaced the bearing hub and the sensor, the vibration has reduced greatly below 120 km/h. However a more pronounced vibration occurs over 120. I have taken the car in for balancing, alignment, checked for warped wheels as well. No negative news on those, so I now suspect it could be my cv joints, what do you guys think?
'91 BMW 318i (Sold)
Re: ABS ESC error
Post by panic-mechanic » Mon May 27, 2019 9:11 am
anything is possible. But a cv that will make vibration almost surely have to make noise too. Unless it has gone all dry but then there should be obvious grease all over the place.
Abominable_Snowman
Re: ABS ESC error
Post by Abominable_Snowman » Mon May 27, 2019 9:32 am
I've pulled the wheel off and had a look around for grease, couldn't see any, the boots still look intact. The cv does have some rotational play (held onto the brake disc and tried to rotate it, had some play before it turned the axle. Could this play be indicative of damage?
Couldn't hear the usual clicking noise when turning full lock, however, at high speeds, there is that vibration at high speed and also has vibration during acceleration (should have mentioned that).
Thanks for the feedback Panic, I have a mate coming over today to help with the diagnosis. I'll post an update afterward
'91 BMW 318i (Sold)
Re: ABS ESC error
Post by panic-mechanic » Mon May 27, 2019 11:25 am
Vibration during acceleration might be inner cv joints.
Abominable_Snowman
Re: ABS ESC error
Post by Abominable_Snowman » Tue May 28, 2019 1:50 pm
Yup, I believe so too. So after running VCDS again, still no luck in resolving the ABS issue. I'll be putting the car on stands this weekend and I'll have to test cabling from one end to the other to hopefully find the gremlin.
If time permits, I'll also change out the CV's and post an update.
'91 BMW 318i (Sold)
Pik Sooter
Car Make: Toyota
Membership No: 1893
Re: ABS ESC error
Post by Pik Sooter » Tue May 28, 2019 4:06 pm
Sorry that you still facing these issues bud. Think of it this way, if you find the problem, let's say it's inner CV's, by the time you have changed that, your front suspension setup will be almost completely overhauled. LOL
