Fi conversion
Evin
Fi conversion
Post by Evin » Tue May 14, 2019 2:00 pm
Hi guys need some help I'm going to convert from carb to fi.on my golf2. I have most parts. Intake, injectors, loom and open ecu box. They say I only need to fit a feul injection pump from mk1 is any other easy to get this setup going. My golf is fiited with mp9 head all ready. Thnx in advance
missioner
Car Model: '87 MK1 Golf Citi
Re: Fi conversion
Post by missioner » Tue May 14, 2019 9:21 pm
Evin wrote:Hi guys need some help I'm going to convert from carb to fi.on my golf2. I have most parts. Intake, injectors, loom and open ecu box. They say I only need to fit a feul injection pump from mk1 is any other easy to get this setup going. My golf is fiited with mp9 head all ready. Thnx in advance
Use the search function.
Way to many threads regarding this topic.
Mk1 doesn't fit mk2. Get the correct setup for your car from a fuel injected mk2.
Saiendra
Criminal Troll.
Car Model: 2019 Polo Vivo 1.4 C/Line
Re: Fi conversion
Post by Saiendra » Tue May 14, 2019 9:48 pm
MK2 FI has a surge tank coupled with an intank lift pump.
Plenty info available on the search function.
Daily - Limestone Grey 2019 Volkswagen Polo Vivo 1.4 Comfortline.
Re: Fi conversion
Post by panic-mechanic » Wed May 15, 2019 12:59 pm
If you fit a mk1 pump then everytime the tank gets half the car will start dying or surging and the pump will not last very long. You are making it suck fuel up from the tank which it is not designed to do. it will sort of work but give you trouble in the long run.
