8v dicktator wiring diagram without tp100
mike65
Registered for: 10 years
Car Model: mk1
Post by mike65 »
Hopefully this will help someone struggling.if you need any advise feel free to ask im sure alot of guys here are pros with this.Image
Sent from my SM-J200F using Tapatalk
Watch this space
PapaJo
Car Make: VW's
Re: 8v dicktator wiring diagram without tp100
Post by PapaJo »
Awesome, Mike65.
mike65
Car Model: mk1
Post by mike65 »
PapaJo wrote: Thu Nov 29, 2018 9:37 pm Awesome, Mike65.
No problem papajo. Just would like to help others where i can and also need help from other in my next setup and just sharping my overall knowledge on both wiring and mechanical :grin:
Watch this space
MerlinShane
Registered for: 6 years 4 months
Car Model: 79 MK1 Golf
Post by MerlinShane »
Hi Guys, does anyone have a picture of the idle stabilizer?
My car has the 8 pin TPS, and I'm struggling to figure out the wiring for the dicktator,
MerlinShane
I found a video online and the guy said these wires are for the 8 pin TPS, but the idle is horrible and it revs up on its own,
PIN1- +12v (Pin 8 on Dicktator)
PIN2- IDLE Control Negative (Pin 18 on Dictator)
PIN3- Not Used
PIN4- +5v (Pin 14 on Dicktator)
PIN5- TPS Signal (Pin 3 on Dicktator)
PIN6- Not Used
PIN7- Ground (Pin 9 or 10 on Dicktator)
PIN8- Not Used
PapaJo
Car Make: VW's
Post by PapaJo »
MerlinShane wrote: Tue Mar 28, 2023 9:15 pm I found a video online and the guy said these wires are for the 8 pin TPS, but the idle is horrible and it revs up on its own,
PIN3- Not Used
PIN6- Not Used
PIN8- Not Used
Check out the Dicktator manual. It gives you the basic setting explanation and then you work it out from there. Important to have the minimum opening and home position set to get a stable idle.
