Not starting first time
Posted: Sun Nov 18, 2018 1:14 pm
by Geody
Hi, I have a problem on a 1.4i Golf 1. Does not start first time but only the second time if switched off on and off quickly. if the delay is too long, it doesn't start. I repleced the coil, (three pin all in one cdi) but has not cured the problem. Has anyone had this problem, if so what was the cure? Any suggestions or help would be appreciated.
Thanks in advance
Re: Not starting first time
Posted: Sun Nov 18, 2018 2:11 pm
by chucker02
Fuel rail not leaking internally? Try switching the ignition on for a few seconds then off and back on again and try starting it like that
Posted: Mon Nov 19, 2018 12:38 am
by Geody
Not fuel related, first start attempt, no spark, second attempt spark. If second attempt is delayed, no spark. New ignition switch and coil, still the same problem. I will replace the dizzy and see
Posted: Mon Nov 19, 2018 7:27 am
by chucker02
Good luck then
