New Polo AW Fog Light Change
Kavi4GP
Car Make: Toyota
Car Model: Corolla D4-D
Membership No: 2016
Post by Kavi4GP »
Just for added information as opposed to the 6R and 6C where the front grill is removed to take the fog unit and bulb out the new AW model uses a far more user friendly design
Turn the wheel to point inside on the side you want to open, it has a round clip of lid on the inner wheel lining.
Turn it anti-clockwise to unlock amd pull off.
If you look inside you will see the wire connected. Push lower lock tab and release, do this before trying to turn the bulb as its designed to not turn with plug on.
Then its just to remove and replace.
Reverse the process for the fitment(again ensure bulb is in and turned clockwise before inserting the connector).ImageImage
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
