Tire pressure sign doesn't want to go off on dash polo 6 bro
Yusuf333
Car Model: Polo 6r GTI
Post by Yusuf333 » Sat Aug 11, 2018 4:35 pm
I have a 2013 polo GTI,and I have a problem with it, my tire pressure monitor sign doesn't want to switch off on the cluster, and the drivers side heated seat just switches off and on
Do you guys have any suggestions or solutions
Yusuf
PapaJo
Re: Tire pressure sign doesn't want to go off on dash polo 6 bro
Post by PapaJo » Sun Aug 12, 2018 1:10 am
Did you check the tyre pressures at a garage and inflated all tyres to the correct pressure?
Once you have done that go into the tyre monitoring menu on the radio display and check that all 4 wheel tyre pressures are reading correct. Then you reset it on this display.
if pressures are correct (all within 0,1 bar from each other and above the warning pressure value for the ride setting, eg comfort) and does not want to reset or one wheel is reading way out from others, you have a problem and possible tyre pressure failure in that tyre and needs to be replaced.
MAI_6R
Car Model: 2018 Polo GTI
Post by MAI_6R » Sun Aug 12, 2018 6:19 am
Make sure tire pressures are correctly filled thereafter press and hold the tpms button in the cubby till you hear a beeping sound.
2018 Reef Blue Polo Gti
2016 Reflex Silver Polo Gti manual
2014 Deep Pearl Black Mk7 GTI
2013 Candy White Polo GTI Revo2
Car Make: VW, VW, Aprilia
Car Model: VR6, Caddy, RSV4
Post by Jetta2 » Sun Aug 12, 2018 7:48 am
Never trust the pressure gauges at garages. Get yourself a decent tyre pressure gauge and check pressures yourself at least once a week.
2017 Caddy Maxi 2.0 TDI
///M
Post by ///M » Sun Aug 12, 2018 4:03 pm
What area do you live in? Garages must be really **** there...
