VW Citi Golf 1.3---Coolant light comes on sporadically
Daylon
Post by Daylon » Fri Aug 10, 2018 1:03 pm
Hi All
I have a 1995 VW Citi Golf 1.3.
The coolant light has started to come on in the past few weeks, it does not come on all the time, it is very random. The heat gauge is normal, and the radiator fan does kick in if the heat gauge goes over half. The car is not using antifreeze.
Any ideas what could be causing this? Is there any reason for me to worry that there is an issue with the coolant system?
Regards
Daylon
Car Make: VW, VW, Aprilia
Car Model: VR6, Caddy, RSV4
Re: VW Citi Golf 1.3---Coolant light comes on sporadically
Post by Jetta2 » Fri Aug 10, 2018 2:52 pm
Not using any sort of anti-freeze/coolant?
Bad idea if that is the case.... drain, flush/clean, use proper coolant (G12 from Goldwagen).
2017 Caddy Maxi 2.0 TDI
Post by panic-mechanic » Fri Aug 10, 2018 7:49 pm
could be the level sender that is iffy. Swop the level sensor if loose or swop the bottle if it is cast in.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
