Coolant Thermostat Assembly
Conroy
Post by Conroy » Thu Jul 12, 2018 11:20 pm
Have a water leak on a Golf 7 TSI.
Coolant Assembly is leaking water. Is there anyone that had the same problem. And also im not a machanic can i change this myself or should the dealer change it rather
Ian_F
Chairman
Chairman
Car Model: Phantom Golf 6R
Membership No: 1846
Re: Coolant Thermostat Assembly
Post by Ian_F » Fri Jul 13, 2018 8:29 am
Morning and welcome.
Post moved to correct section
Post by panic-mechanic » Fri Jul 13, 2018 9:20 am
Yes common as chips. You'll see the same thing if you search the forum for common mk7 problems.
Without knowing what you are capable off it's impossible to say if you can DIY it. for a start the intake manifold has to come off.
So look if you can manage that first by taking a good look in the engine bay. If you think you can't do that then don't even consider it further.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
mebs
Car Model: GTI Ed35
Post by mebs » Tue Jul 17, 2018 10:03 am
I had a similar issue on my S1, luckily i have plan. They had to replace the thermostat and a few other bits around there.
Scary that the bill was like R10k.. Hopefully your is not as serious.
Good luck
//M Power
