Engine turns but no start
caddy club
Car Model: Caddy AGG 2L Carb
Post by caddy club » Wed Jul 11, 2018 6:43 am
Just a general question, when they are saying you droppend valve what exactly does it mean, does it mean you over revv and the valve drops from the head to the piston and comes completly out of the head
If a valve drop or a valve gets bend by cambelt broke, will the motor not turn over
Is the HM 1.6 caddy carb engine a non interverence motor
Caddy Club AGG 2L Carb 1998 model
ICE King
Re: Dropping a valve
Post by ICE King » Wed Jul 11, 2018 8:16 am
Dropping a valve doesnt necessarily means over revving , it's one of the reasons but yes , the valve drops from the head onto the piston/into the bore. - This is disastrous whether the motor is a non interference design or not.
however on a non inference motor , valves are safe if the cambelt breaks - even if there's a valve stuck open - as long as it doesn't drop.
(the piston and valve will never meet each other even if the valve is open aka non inference motor)
Motor will not turn over if there is anything in the path of the pistons - Like the saying that goes " the motor skoped vas"
Rides:
caddy club
Post by caddy club » Wed Jul 11, 2018 9:03 am
Because my enjine does not start and the starter motor does not turn the motor but the engine does turn by hard
PoloMike
Car Model: 1998 Polo Classic 1.8
Post by PoloMike » Wed Jul 11, 2018 10:34 am
Its probably your starter or battery then. If you dropped a valve it wouldnt turn by hand.
1998 Polo Classic 1.8 with added "benefits" :violin:
caddy club
Post by caddy club » Wed Jul 11, 2018 10:38 am
Damn this is good news,,,i will let you know
Wolf Mk2 16V
Post by Wolf Mk2 16V » Wed Jul 11, 2018 2:58 pm
:lol: phew!
2015 VW Golf Gti Oettinger (okay okay software only!)
1990 Golf GTi 16 Valve Executive (KR Baby!)
1993 Citi Golf Designa 1800
2015 VW Move Up!
2014 VW Transporter T5 Single Cab Long Wheel base
2013 VW Transporter T5 Single Cab Long Wheel base
2002 VW Citi Golf Chico 1.3 -sold :(
caddy club
Post by caddy club » Wed Jul 11, 2018 6:43 pm
Urgent help guys
The motor turn but do not start at all, all engine oil came out of the oil filter and this is strange, car did not run without oil
Oil was checked before tuning the engine, i hpe its not conrod that broke or something simaliar
ICE King
Re: Engine turns but no start
Post by ICE King » Thu Jul 12, 2018 10:16 am
spark & fuel?
Turning by hand is somewhat good news ,You should do a Compression test , It that checks out , drain oil , remove sump and have a look
Rides:
PoloMike
Post by PoloMike » Thu Jul 12, 2018 10:19 am
have you just recently purchased this vehicle?
caddy club
Post by caddy club » Thu Jul 12, 2018 10:54 am
No i’ve been driving this caddy for long now,,so if turns by hand it means no conrod or valve damange hence its turning,,,compression test not done yet but what bothers my how did the oil filter came loose and all oil coming out there,,,when i looked at the oil filter it was loose with the oil filter seal sticking out on the one side :eek:
Once again thanks for the help,,, just hope its not major
Post by panic-mechanic » Thu Jul 12, 2018 11:02 am
Often happens when you fit a double seal at a service. So pull the filter off and look at it carefully.
BUT BUT BUT
ALSO here is the fun kicker. If your oil pump pressure release valve has failed this happens. It makes so much pressure that it forces oil past the seal - this also pumps up the lifters so much that the valves are left standing open so won't run. I have had that twice in my life before - Change the oil pump in that case.
It will crank like it has no compression - soo just huhhhhhhhhhhhhhhhh from the starter motor - not chi chi chi chi .
Last edited by panic-mechanic on Thu Jul 12, 2018 11:04 am, edited 1 time in total.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
PoloMike
Post by PoloMike » Thu Jul 12, 2018 11:03 am
How much oil is left in the sump? You musnt over tighten oil filters or they bulge the seal and that will loosen off the filter.
PoloMike
Post by PoloMike » Thu Jul 12, 2018 11:05 am
BUT BUT BUT
Ive also seen this with someone that tried to use oil thickner to reduce a bearing noise and blew the oil out the top of the filter. Wasnt very pretty
caddy club
Post by caddy club » Thu Jul 12, 2018 11:44 am
Car was running fine and all of the sudden this happens
@ at panic this is exactly what she is doing, just turning the motor like there is no compression
caddy club
Post by caddy club » Thu Jul 12, 2018 11:47 am
Dont think filter was overtigten, luckly i didnt run like this on the road it was a matter of just starting and she died and oil coming out
Post by panic-mechanic » Thu Jul 12, 2018 6:59 pm
change the oil pump.
'09 Audi Q5 3l tdi
caddy club
Post by caddy club » Thu Jul 12, 2018 7:21 pm
Thanks for all the help guys
Any suggestions where to buy and at what iam i looking at price wise, the one that i have in now is febi
Westrand area
caddy club
Post by caddy club » Sat Jul 14, 2018 1:59 pm
Thanks for all the help guys car is running again it was the oil pump :hug:
caddy club
Post by caddy club » Sun Jul 15, 2018 7:48 am
Besides that my caddy is running now there is a bearing knock so yes i have engine damage, so crank needs to come out sometime
PapaJo
Post by PapaJo » Mon Jul 16, 2018 7:18 pm
Oil related issues normally result in engine rebuild, not nice. Good luck with the motor rebuild.
ICE King
Post by ICE King » Tue Jul 17, 2018 8:36 am
Some are lucky to catch oil issues before further damages, others not. All the best with the rebuild
Rides:
caddy club
Post by caddy club » Fri Jul 20, 2018 9:24 am
Morning guys
I know it is not advisible to drive like this but will it cause more damange if i drive it temporarly until i can fix, i will also need you’ll help with the rebuild
PoloMike
Post by PoloMike » Fri Jul 20, 2018 9:26 am
HI
not advisable. I will send you a private message.
ICE King
Post by ICE King » Fri Jul 20, 2018 9:30 am
Not advisable , if you insist , if it's already loud then you don't have much time , If it's soft, you can drive it till it's louder.
Worst case , the rod will let go and destroy block.
As it stand now , Hopefully all you need is a new set of bearing's , If you keep driving it , you'll damaged the entire bottom.
Rides:
PapaJo
Post by PapaJo » Fri Jul 20, 2018 11:04 am
I wouldn’t drive it with a knock even a soft knock. This will cause damage to the crank and then you have to strip the whole bottom end and rebuild.
You might be lucky that you only need new bearings now with the soft knocking. When you replace bearings, measure for oval journals and check for grooves or scoring marks on journals. Any of above and rather do a full bottom end rebuild now to save you having more or bigger issues later on.
