Advice wanted: Gear shift cable lubrication
VAG Fan
Post by VAG Fan » Wed Jun 13, 2018 2:37 pm
The gear shift on my Golf 4 is quite stiff, and with the engine off, I can hear and feel some squeaking from the area underneath the gear lever. I'd like to start by lubricating as much as possible of the gear shift mechanism, preferably including the ball, the cables, and all levers/eyes - and any "gates", if there are any in the Mk 4.
Can anyone give me advice on
... which lubricant to use for the ball, the cables and the levers/eyes
... whether I need to access the inner ends of the cables (I've read that this is only possible from below, so I would need to drop the exhaust for that)
Any other advice welcome.
Re: Advice wanted: Gear shift cable lubrication
Post by panic-mechanic » Fri Jun 15, 2018 6:12 am
Pull the gear lever boot off first and see what you can get hold of from the top. The ends of the cables on that side you literally can only get hold of by removing the entire mechanism. Much easier to try to do the cables themselves from the engine side.
lubricant really depends on what you can get hold of or want to lube. If you can get the lever off the pins they are on then some grease is the best. The cables itself you literally won't be able to get anything else than like Q20 or such inside.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
