Caddy 1.6 carb TP100
vishaldee
Car Model: 05 caddy mk1
Post by vishaldee » Wed Jun 13, 2018 7:04 am
Hi Guys
So i have a 2005 caddy bakkie 1.6 carb. Vehicle was starting and dying within seconds....... mech informed me that the TP100 module is blown.
What is required to have one changed out. What is involved in this process......Goldwagen sells them but do they require coding or are they plug and play?
Thanks in advance
PapaJo
Re: Caddy 1.6 carb TP100
Post by PapaJo » Wed Jun 13, 2018 10:26 pm
Hi Guys
Thanks in advance
2005 model does not have a TP100. The 2004 and ipward models have a 3 pin square coil unless your Caddy was converted to a round bottle coil and TP100. Doyble check first what coil you have.
Replacing a coil (round or square tyoe) does not require recoding.
vishaldee
Post by vishaldee » Fri Dec 28, 2018 12:33 pm
I have a square 2pin coil.
PapaJo
Post by PapaJo » Fri Dec 28, 2018 12:41 pm
Then no TP100
vishaldee
Post by vishaldee » Fri Dec 28, 2018 12:43 pm
Tci
Post by panic-mechanic » Wed Jan 02, 2019 6:31 am
if it has a 2 pin coil then it definitely has a tp100..
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
