VW T5 Kombi
Sech
VW T5 Kombi
Post by Sech »
I drive a VW T5 kombi 1.9 2009 model. Engine was redone after the top cylinder cracked due to a Cambelt failure. When I start car white smoke comes out from the pipe and has burning sensation in my eyes. It soon disappears after a while.
When driving it turns to loose power and start shaking. I then switch off engine and start again. I put the injector cleaner in the diesel tank and the issue continues. I checked and cleaned the EGR valve. The car chows a lot of diesel when driving.
The diagnostic machine does not give any errors. What could be the issue and where can I take the car to for assistance?
PapaJo
Car Make: VW's
Re: VW T5 Kombi
Post by PapaJo »
Was cam and diesel pump alignment done? Does it lack power?
Re: VW T5 Kombi
Cpossible timing issue or one of thensensors like water temp not plugged in/dead. Of course you give a location it will be a lot easier to refer you to somebody.
Sech
Re: VW T5 Kombi
Post by Sech »
I am located in the Randburg/Fourways area. Many people also suspects timing but also injectors as well which might be due to the sensors. I will update forum once this has been checked. It does lack power.
Re: VW T5 Kombi
that area try vagspec centre. Highly recommended by Dazza.
Sech
Re: VW T5 Kombi
Post by Sech »
Problem sorted. Injector seals changed. Timing sorted. No more smoke or misfire. Have been advised to change the injector harness soon. Thank you guys.
PapaJo
Car Make: VW's
Re: VW T5 Kombi
Post by PapaJo »
Sech wrote: Wed May 30, 2018 11:50 am Problem sorted. Injector seals changed. Timing sorted. No more smoke or misfire. Have been advised to change the injector harness soon. Thank you guys.
Great stuff.
SechabaP
Re: VW T5 Kombi
Post by SechabaP »
:bang: :bang: White smoke from the exhaust.
PoloB
Car Model: POLO 6S
Re: VW T5 Kombi
Post by PoloB »
Sech wrote: Fri May 04, 2018 10:36 am I drive a VW T5 kombi 1.9 2009 model. Engine was redone after the top cylinder cracked due to a Cambelt failure. When I start car white smoke comes out from the pipe and has burning sensation in my eyes. It soon disappears after a while.
I will forward you details
Vw Polo 6 Sedan
Quantum Tunning Software
Eibach Springs
Smoked Tail lights
17 Inch A-Line Spree wheels
Thekogm
Car Make: VW & VW
Car Model: 95 Polo 1.4i, 03 Transporter
Re: VW T5 Kombi
Post by Thekogm »
panic-mechanic wrote: Mon May 07, 2018 7:33 pm that area try vagspec centre. Highly recommended by Dazza.
Do you know who does the Bloemfontein area?
:type: or on the phone...
