Not Vag Related - Toyota Corolla
Keshan_G
Registered for: 10 years
Car Model: Polo 9n3 GTi
Post by Keshan_G »
Howzit guys,
I have a 2003 toyota corrolla 180i gle automatic, the car has about 250 000 odd kms on it right now,
the issue im having is that when the car is cold, it struggles to idle and cuts off, you have to keep your leg on the accelerator holding a constant rev or the car cuts off. however when the car is warm ( needle on heat gauge at the half way mark) the car drives and idles normally with no issues what so ever.
could this be a symptom of a blocked catalytic converter or faulty throttle? reason i ask about the throttle is because when the car went to the agents for a service, they apparently said the fault is the throttle body, but somehow i am not convinced that the throttle is the problem..
any help would be appreciated,
Thanks guys
'07 Blue Polo GTi 9n3
Powerflow 76mm DP- 63mm Zorst> 90deg intage/cone> Forge TIP> Forge Splitter DV> Forge Charge Pipe> Cupra FMIC> BC Coilies> R8 Coilpacks> 4Bar FPR > Devils Own Stage2 WMI
