Good day all
This is on behalf of a friend of mine here at work who's girlfriend has the car. He is very mechanically inclined as he has done many engine overhauls, gearbox overhauls and in general car trouble shooting and repairs.
Background:
Car has recently started using water. He says it needs 500ml top up every second day. He has gone through the engine bay with a strong flashlight each and every corner and cannot find any leaks or markings indicating a leak. Is head gasket a possibility? No steam coming from exhaust.
Car has the following symptom also that we don't know if it is right. When you remove the oil filler cap, there is a strong vacuum from the filler. It wants to such back the cap. He also says the car changes it's idle sound to a erratic idle when cap is removed. We have never experienced this with other cars before.
2012 VW Polo 1400 CLP engine trouble shooting help needed
- Registered for: 18 years 11 months
1977 Datsun 1200GX
Wife's car: 2019 Suzuki Ciaz
1977 Datsun 1200GX
- Car Model: '13 PGTI DSG
Re: 2012 VW Polo 1400 CLP engine trouble shooting help needed
My wife's got the exact same issue I have traced it to the water pump, it gets hot expands and lets out some water then it drops into the drip tray and eventually it drops out there onto the ground. As soon as i get time and money I will replace the pump and gasket on it. We also put in water everyday to top it up, it isn't ideal but its until we can buy the pump so I can fit it. Bare in mind the pump is quite hidden so tracing the water is tricky. Might be worth you checking it you might have the same issue as me.
Some engines have positive crankcase ventilation, i.e. the blow-by gas is drawn into the inlet duct after the throttle. This puts the whole crankcase, tappet cover etc. under vacuum. If you open the oil filler cap, then you introduce a whole lot of unmetered air into the combustion mixture, which explains the erratic idle. My Audi actually dies completely when I open the oil filler cap.
Waterpump was replaced couple thousand km ago with a genuine VW one. I spoke to him and he said the first things he checked was waterpump and whole cooling system for leaks.
Thanks VAG Fan. Will inform him.
1977 Datsun 1200GX
1977 Datsun 1200GX
use g12 or any of the modern coolants recommended for the car. By using a blacklight it actually flouresses and you can see where it leaks. also leaves an eye visible whiteish powder trace. If no visible leaking then possibly head gasket.
