Touareg V10 expert
Posted: Wed Feb 07, 2018 12:11 pm
by Chigumula
Hi there, need a turbo actuator replacement and re-mapping for my beloved V10 Touareg 2007, coming from Malawi looking for a experienced RMI workshop in Gauteng who knows the V10 in and out, thanks for any advise
Re: Touareg V10 expert
Posted: Wed Feb 07, 2018 12:33 pm
by dazza
Stephan is who you are looking for. Check the advertisers section for Panic's Place.
If you need RMI workshop then check out VagSpeccentre.co.za
Posted: Wed Feb 07, 2018 1:24 pm
by Howie-WP
Panic aka Stephan
Posted: Wed Feb 07, 2018 2:26 pm
by Neuk
Stephan could help but I don't he is RMI approved, so Vag Cpec Centre is probably your best bet.
Posted: Wed Feb 07, 2018 6:13 pm
by Unobeat
You won't go wrong with Panic Mechanic(Stephan).
Posted: Fri Feb 09, 2018 2:31 pm
by 1 Eyed Monkey
Magoo is RMI approved as well.
Posted: Mon Feb 19, 2018 12:09 pm
by panic-mechanic
a) you do not get the actuator loose. So unless you have sourced one that is known to be alive form a crashed car you cannot just buy one new and fit.
b) if you buy a turbo new to get the actuator it is advised to swop both sides because it is an engine out job to change.
if you are looking for an RMI workshop because you think that guarantees quality of work you are in for a rude awakening.
Not many places can and will take the engine out of a touareg or has the tools to do it.
But yeah I am not and will never bother with RMI.
