mk1 golf leaking carb
chico16
Post by chico16 » Mon Nov 27, 2017 9:54 am
I have a 2001 1.6 citi chico mk1 golf. I noticed smoke coming from under the bonnet. I noticed that the carb was leaking onto inlet manifold and dripping onto exhaust. I can see where it is coming from- against the carb housing at front looks like a brass ball sticking out, thats where its leaking. I dont want to drive like that, in case it catches fire. Can someone please give me some advice on how to go about to repair it?
Thanks.
Re: mk1 golf leaking carb
Post by panic-mechanic » Mon Nov 27, 2017 10:14 am
Buy a crb overhaul kit, take ot apart, change the seals and gaskets. Put it back together.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
VAG Fan
Post by VAG Fan » Mon Nov 27, 2017 1:04 pm
Those small balls are pressed / peined into the bores that run inside the housing, to seal them. IMHO replacing the seals and gaskets will not fix this problem.
I had a similar problem on my Keihin many moons ago: the one ball seal squirted petrol every time I pressed the accelerator pump, and I actually managed to seal that area by degreasing it properly and covering it with Pratley steel.
Sean Trollope
Car Make: VW. Hyundai.
Car Model: Citi golf. Hyundai i10
Post by Sean Trollope » Thu Nov 30, 2017 10:30 pm
Go to scrap yard and get a carb. Overhaul it and put it in the car.
chico16
Post by chico16 » Fri Dec 01, 2017 4:18 pm
Thank you all for your input. I managed to seal it with abro putty which is chemical resistant. The car starts easier now also, previously the carb would drain cos of the leak, making it take longer to start as it first has to fill carb again. Thanks.
Sean Trollope
Post by Sean Trollope » Fri Jul 13, 2018 11:26 pm
Sorry to being the old thread back to life. Just had exactly the same issue.
marzbars
Car Model: 1984 Jetta GLS Auto
Membership No: 1316
Post by marzbars » Mon Jul 16, 2018 3:22 pm
I have a Weber 36DCD and Manifold. PM me
